What do you think about this cam (turbo 5.3l)
Old 10-27-2014, 03:51 PM
99tramsamc/fia's Avatar
Default What do you think about this cam (turbo 5.3l)
SBE 5.3, 853 heads, ls6 intake, 75 mm t.b, with s475 83mm 1.10t6. Looking to make 700 ftlbs. On e-85.
It's going in a 4500lbs 4x4 75 k10, Turbo 400, 208 transfer case,
4:10 gears with 37 inch tires.
Thanks
Old 10-27-2014, 06:14 PM
Guard dog's Avatar
Stump puller for sure.
Old 10-27-2014, 06:38 PM
Forcefed86's Avatar
I'd run it... My 212/212 @ 112 makes some power down low for sure. I've run it in a 5.3 and a 4.8.
Old 10-27-2014, 10:13 PM
Old 10-27-2014, 11:35 PM
9 Second Truck Club
stock48's Avatar
It will definitely make some tq, but lift seems really high for that duration. Lobe might be really aggressive.
Old 10-28-2014, 10:05 AM
LJMSJohn's Avatar
LSL/LSL lobes...
I wouldn't run it in a turbo motor. Too aggressive of a lobe imo.
Old 10-28-2014, 10:09 PM
Originally Posted by LJMSJohn
LSL/LSL lobes...
Meaning? Hard on valve springs?
Thanks
Old 10-29-2014, 09:49 AM
LJMSJohn's Avatar
Thanks
Yes hard on springs... will get into a valve float condition earlier in the rpm range.
Old 10-29-2014, 03:37 PM
So I can get this cam for FREE. Machine shop has it sitting on the shelf. Should I use it or put the stock one back in. Maybe keep rpm's below 6500. Is there a option for springs or **** the cam stock for now and get one later.
Thanks
Old 10-30-2014, 05:56 PM
LJMSJohn's Avatar
Free now.... could end up costing you alot more later...
If you are dead set on running it because its free... buy a BTR Platinum spring kit and put on the heads with a set of matching pushrods. roughly 400 bucks for both.
Old 10-30-2014, 07:00 PM
burbalanche's Avatar
Not to hijack but how would a 206/214 527/549 on 112 be in a 4.8/s475 be in a roughly 5000lb truck?
Old 10-30-2014, 09:34 PM
I knew it was to good to be true. **** that cam.
I'll be giving you a call. Next week.
Thanks
Old 10-31-2014, 06:00 AM
yenkomike's Avatar
I run the 54-450-11 that is very close to those specs. and mine works very good in a 6.0
Old 10-31-2014, 05:14 PM
Oh ok was just wonderig if i would gain anything with another better custom cam.
Quick Reply: What do you think about this cam (turbo 5.3l)
