EGT monitoring
Old 12-01-2015, 03:33 PM
oscs's Avatar
Default EGT monitoring
How many of you guys run an EGT guage on your cars? In my old world (diesel) you live and die by it. Im sure it is just as important on a Gas motor but how much really?
Old 12-01-2015, 03:39 PM
MMorgan9812's Avatar
I go by the saying "you can never know to much about what your car is doing" especially with all the add-on aftermarket parts and engine builds we do
Old 12-01-2015, 03:44 PM
oscs's Avatar
I generally live my life by this rule of thumb as well. I really cant get enough information about what is going on inside my motor. With that said i would like to hear from people that run them. Maybe someone can share a story about how they a saved their *** or helped diagnose a problem.
Old 12-01-2015, 03:51 PM
rotary1307cc's Avatar
http://holleyefi.biz/REDLINE-8-CHANN...ED-EGT-KIT.htm
Integrated into the dominator. I'd like this
Old 12-01-2015, 03:54 PM
oscs's Avatar
Hell i was talking about running one on each bank
Old 12-01-2015, 04:00 PM
Won't tell much
8 channel you can really do something
Shutdown if something happens to a cylinder where it rises above set limit.
See trends of cylinder distribution and correct with trims
Say like u last week... You loose a cylinder...... Have it set to shutdown if say above 200kpa any cylinder is below a set egt limit
Ect
Old 12-01-2015, 04:19 PM
oscs's Avatar
Originally Posted by rotary1307cc
Won't tell much
Ect
Yeah i dig the idea that's for sure just not looking to drop 1k on the idea. The actual gauges are cheap. I wonder if i could find away to have the holley monitor them all pretty cleanly.
Old 12-01-2015, 04:28 PM
Clean as in r software or clean to the eye under the hood?
Old 12-01-2015, 04:31 PM
oscs's Avatar
Software. Im assuming each sensor would take up a output?
Old 12-01-2015, 05:19 PM
Yes correct. But the dominator has plenty. That kit comes with the holley connector. It simply plugs in and you assign the pinmap and done.
I will try to find the vid of software layout on a data log. It is very cool
Old 12-01-2015, 05:45 PM
Old 12-01-2015, 06:53 PM
oscs's Avatar
This is yours? Damn that's badass.
Old 12-01-2015, 07:04 PM
dckmn52's Avatar
EGT monitoring is a cheaper alternative to doing this:
Wideband monitor and self fuel correction for each cylinder with MS3Pro.
I feel like r1307 has been saved by his Holly a few times now, considering the amount of safety measures in place
Old 12-01-2015, 07:07 PM
gtfoxy's Avatar
Add post turbo EGT's to pre-turbo and you can determine how much enthalpy the Turbo/'s systems are using/losing.
Old 12-01-2015, 09:30 PM
Ha I wish. I have an HP. If I had a dominator it would be on the Christmas list lol
Old 12-02-2015, 12:41 AM
8 Second Truck Club
Blown06's Avatar
For turbo guys that put them in the collector pre turbo, I'd say EGT is really kind of a waist.
It can have benefits in N/A or blown **** if monitoring each hole.
Old 12-02-2015, 07:53 AM
And how could you say that?
Old 12-02-2015, 08:08 AM
oscs's Avatar
Yeah I'm not following. At the bare minimum having one pre turbo on each bank can tell you differences between the two.
Old 12-02-2015, 12:14 PM
Meth Sled's Avatar
I would run a sensor pre-turbo/wastegate on each bank, yeah it's not as good as a sensor on each cylinder but it's better than not knowing at all. And will help with any diagnostics or trouble shooting that may ever occur.
Old 12-02-2015, 01:13 PM
Man-Crush Warning
Shownomercy's Avatar
Make sure you let the diesel crowd know they are doing it wrong .
My truck has one pax manifold, 100* per 10mph and I get good mpg.
Quick Reply: EGT monitoring
