Any feed back on the S300 SXE stuff yet?
Took me a couple of months to get, but my S364.5's came in. Anyone run these with the larger unclipped turbine wheels yet. The only info I've seen has been from the diesel crowd.
I had a 64/71/.8(T3) secondary on my 5.9 cummins that would start raising the needle at about 1500 rpm. Don't know if it's apple to apples, but I figured that two of them on a slightly larger gas engine should spool up by 3000(hopefully a bit sooner). Time will tell.
I've the 64's with the 68mm wheel on mine and I'm quite happy with them.
There was no 73mm option when I got mine, at least not with factory built units, think mine were the first genuine BW 64mm units anyway.
Havent seen anything so suggest I need anything larger than the 68mm anyway, although it would be an interesting experiment if someone wanted to donate a pair lol
