Theres gotta be a better way(??)6.0 Procharger woes..
Old 06-23-2016, 11:48 AM
T/AWS6969's Avatar
Question Theres gotta be a better way(??)6.0 Procharger woes..
Ok so I have a forged LQ9 that I am building. Come to find out the 6.0 block doesn't have the accessory holes for the alternator bracket from the LS1 that I have. this bracket also supports the Procharger and bracket as well. on the LQ9 there only the bottom hole and seen video of guys tapping one more hole on the right side of the block. But there is no way to drill and tap a hole just to the right of the timing cover. I have heard guys are using only the 2 bolt holes to support the alternator, aster bracket AND procharger. Sounds like not nearly enough support to me. I talked to Bob at Brute and he said guys just run with those 2 bolts holes. Anyone got another way?? any advise?? thanks guys!
Old 06-23-2016, 11:54 AM
T/AWS6969's Avatar
I guess i was hoping someone somewhere has developed something else by now. do you know if anyone has made a Alternator relocation bracket? if i am only going to have only 2 holes to bolt on that side i would rather dedicate it to the D1 and Aster bracket and put the alternator elsewhere if possible...
Old 06-23-2016, 11:57 AM
Restricted User
JoeNova's Avatar
Google alternator relocation LS1.
There are probably 40 different brackets out there.
Old 06-23-2016, 12:29 PM
T/AWS6969's Avatar
very doubtful any brackets will work up top with the slope of my trans am hood and air conditioning. Looking for any 1st hand experience..
Old 06-23-2016, 12:44 PM
Rise of the Phoenix's Avatar
I concur. OP, you act like you have a vastly different setup than anyone else who's ran a Procharger setup on a stock factory LQ9 block. Also, if Bob said you can run it with the two bolts, I'd take him at his word. He knows a thing or two about Procharged builds.
Old 06-23-2016, 12:50 PM
high n dry's Avatar
Drill n tAp it for metric bolt... not real hard
Old 06-23-2016, 02:07 PM
cajundragger's Avatar
steel blocks don't have the same holes drilled and tapped as alum blocks.
you just need a template, bit and tap.
Old 06-23-2016, 05:24 PM
Forcefed86's Avatar
ICT billet sells templates. And many brackets. I used the Fbody bracket itself as a template to drill the block.
Old 06-23-2016, 05:51 PM
T/AWS6969's Avatar
ummm yeah i have done this plenty of times. but have been told you cannot tap the area out next to the timing cover. I would like to use all 3 bolt holes so it doesnt flex. but looks like it is..what it is..
Old 06-23-2016, 05:53 PM
T/AWS6969's Avatar
ok..thanks..i was kinda hoping someone has developed a small bracket off the timing cover by now to possibly utilize a 3rd bold so there is no flexing..thanks guys..
Old 06-23-2016, 06:26 PM
Jimbo1367's Avatar
I've seen people merely bolt the Brody alt bracket. And drill throughout that to locate it.
Old 06-23-2016, 09:31 PM
T/AWS6969's Avatar
Huh...brody.. thanks bro I will check it out
Old 06-24-2016, 10:54 AM
Husker98's Avatar
I just recently drilled and tapped a iron 5.3 block while it was in the car. I installed the alternator bracket and used that to start my hole and make sure I was straight and then pulled it off to drill it deep enough. Step 9 drill bit and m10 threads I believe. Thought about just using the 2 bolts but it was fairly easy to do.
Old 06-24-2016, 12:56 PM
SteenH's Avatar
Drill it, you seem like quite the whiner. People are trying to help you and you're pretending there's just no way it will work.
Old 06-25-2016, 01:57 PM
T/AWS6969's Avatar
Thanks bud!..looks like my only option..
Old 06-25-2016, 02:00 PM
T/AWS6969's Avatar
Ummm no not a whiner. Just looking to see if anyone has had experience doing it a diffrent way. Dont be a DB when someone askes a question about trying to do something a better way..
Old 06-25-2016, 04:12 PM
T/AWS6969's Avatar
thank to all that actually had something constructive to say!
Quick Reply: Theres gotta be a better way(??)6.0 Procharger woes..
