rear mount turbo
Old 11-23-2005, 04:58 PM
96ws6cam's Avatar
Default rear mount turbo
i know this might be a repost sorry about that but the search thing doesnt work for some reason...i was wondering what all i will need for a rear mount turbo and also how much money am i looking at spending
Old 11-23-2005, 07:45 PM
black01_WS6's Avatar
about 4500 for system. are you putting it on or someone else. also look into fuel system, rear end, clutch or converter, stickey tires, spark plugs-wires. you can do it cheap and break stuff or spend alot of money and might still break stuff. I am doing everything else before I go turbo, that way it will be less likely to break stuff. I am going to be rebuilding my engine and tranny with a new clutch this winter. you can have about 15 grand into a turbo set up or more, or you can have it for 4500.
Old 11-23-2005, 07:59 PM
pbjones81's Avatar
Default .
are you talking about buying a kit from STS? or fabricating it yourself? Reason I ask is because its not just as simple as buying any turbo and throwing it in the rear of the car.
Old 11-23-2005, 10:06 PM
longrange4u's Avatar
LOL and its not as simple as just buying an STS kit either
Old 11-23-2005, 10:48 PM
96ws6cam's Avatar
well i know that much guys but i am definatly new to the world of FI so i was wondering how much its costed you guys to do yours and yes im talking a custom kit
Old 11-23-2005, 11:50 PM
custom, you are talking around 10,000.
Old 11-24-2005, 10:38 AM
Red91vette's Avatar
If you are going to make your own, I hope you have good fabrication skills and access to machines and materials at a good price. Prices add up real quick, I am discovering that out now. I think it would be best ot just save up for the kit yourself, im waiting for the twin turbo kits coming up, by the time they actually do, I should have enough money, atleast for a hot parts setup and do the rest myself, that's about as custom as I will probably be able to do. Goodluck on your setup, it's not as easy as you may think.
Old 11-24-2005, 12:26 PM
Hahaha well when you include the bigger turbo... fuel system... FMIC... programming... BOV... nessessary driveline mods.... 10k is a good number for the STS as well
Old 11-24-2005, 01:19 PM
abbaskhan's Avatar
it depends on the parts list really. if your decent at welding and fabrication and do it all yourself you can save big. now if you go buy a ball bearing turbo and all stainless burns parts your in some serious amount of $change$.
think bout wat you want down the line and from ther lay it out and then start. if your wise you can probally do it for under 3200. and could see close to if not slightly more than 500rwp.. is that enough who knows?? but that feeling of wow wont last long when you know you can just turn up the boost.
Old 11-25-2005, 04:21 PM
magius231's Avatar
average cost to get an STS kit running is around $5000 with a hopped up fuel system. I don't count driveline mods as you need to do that anytime you make that much power.
Quick Reply: rear mount turbo
