belt drive distributor????
Old 05-11-2006, 02:31 AM
sr71bbjr's Avatar
Default belt drive distributor????
does anyone make a kit for the lsx motors yet?
Old 05-11-2006, 09:37 AM
7 Second Club
Phil99vette's Avatar
Yes, I believe Ronnie Duke was running one. There is a pic in one of the LS1 builders guides.
Old 05-11-2006, 10:46 AM
Worm Boy's Avatar
Here is a pic of mine.
Jesel Belt Drive
Old 05-11-2006, 12:12 PM
chuntington101's Avatar
can i ask why oyu would run one of these when you could have fully mapable ignition?????
thanks Chris.
Old 05-13-2006, 06:45 PM
sr71bbjr's Avatar
Abybody???
Old 05-13-2006, 09:01 PM
TApimp's Avatar
thanks Chris.
coil packs wont make the power he is going for
1BADAIR's Avatar
gm performance has a front cover that uses ford distributors and fuel pumps
Old 05-13-2006, 11:08 PM
SSU Moderator
RyanJ's Avatar
stock GM coils have made 1500hp+, but for some it doesnt seem that simple. Wormboy was using FAST though (W2W only uses BS3).
Old 05-14-2006, 12:44 AM
sr71bbjr's Avatar
So what all do I need in order to make this deal work?
Old 05-14-2006, 02:05 AM
so why cant coils hold up to it????
just wondering coz full electronic ignition will allways make more power than a dissy setup. right??
thanks Chris.
Old 05-14-2006, 08:03 AM
1BADAIR's Avatar
http://www.sdpc2000.com/catalog/4461...rive-Cover.htm
I can't find were is says you need a ford dist, but here is a link to the part
Old 05-14-2006, 09:32 AM
1BADAIR's Avatar
http://chevyhiperformance.com/techarticles/0508ch_carb/
Old 05-14-2006, 10:17 AM
C_Williams's Avatar
Wegner Automotive Research
Wegner Automtive
Charlie
Old 05-14-2006, 10:29 AM
sr71bbjr's Avatar
Wegner Automtive
Charlie
nice.What about a belt drive kit like wormboys since he wont respond to my pm's.
Old 05-14-2006, 01:33 PM
dacajun's Avatar
I'm in the process of doing a front mount dist. What you will need is a Jesel belt drive timing set, $1175. http://www.jeselonline.com/index.php?categoryid=68&
Also the block will need some machining to accept the Jesel belt drive. When running the above mentioned Jesel belt drive you will no longer be able to drive the factory oil pump therefore you will have to install a external oil pump of some sort. I'm running a 3 stage dry sump at the tune of $3000. http://www.moroso.com/catalog/catego...?catcode=14005.
To my knowledge there is not a front mount belt drive dist. available so I'm modifing one for the SBC http://www.jeselonline.com/index.php?categoryid=69&.
Then you will need an igintion system. For that I have an MSD 10. This baby will lite the space shuttle No factory ecm here Accel Gen VII.
I think I have invested around $10000. Oh yea you read that right 10 grand!!! No one said this crap was cheap!! Maybe that stock multi coil system doesn't look so bad now huh?
I hope this answered your questions....
-Dave
Old 05-14-2006, 03:32 PM
sr71bbjr's Avatar
nice info.What if you cant rin a dry sump?
Old 05-14-2006, 04:47 PM
TwnTrboCE's Avatar
I don't understand why people are having trouble with the stock ignition setup. I'm still running stock LS1 coils in my CE spinning it to 7400. We run truck coils on the Formula spinning it 8,000+. Have never had ignition issues. We do run BS3. Has this only been a problem on other systems?
Old 05-14-2006, 05:17 PM
Mr Powell's Avatar
I was going to say you all still have stock style coils.
Now get outside and takes some pics of the CE!!!
Old 05-14-2006, 10:21 PM
427's Avatar
The standard small block front drive dist can be adapted for LS use. If you don't have the FAST ecu, buying a BS3 will cure the ignition problems that drive people to add the dist.
We are a dealer for both BS3 and FAST, call 248-589-1190 and ask for Todd if you need any parts to complete your build.
Kurt
Old 07-26-2007, 03:12 PM
NIIN20's Avatar
Anymore insight on the belt drive kits?
Thanks
Quick Reply: belt drive distributor????
