FMIC Design Flaw
I like my Griffin IC, and I like having big *** pusher fans mounted right on the radiator; that was the solution to my cooling woes. I lost the AC, but I wasn't using it on hot days anyway... because I'd overheat.
Consider a methanol kit if you really want to achieve low IATs.
my car with the biggest A2A intercooler that can be fit in front of a radiator on a camaro my car runs 160-170deg
I didnt notice any changes with the coolant temps (ofcoarse the gauge is stock and not that accurate) but i never had any overheating problems. the IAT where very high though, bout near 200°
with my custom kit the IC is up in the nose with the license area cut out away from the radiator., i have a good temp gauge, so coolant temps are good, and my IAT are much lower i think the hottest i have seen was 130° on a 100° day.
For drag racing this is probably ok, but if i ever take this to a road course I can't see this working. I didn't realize these kits would not work on a road coarse (due to heat build up) when I purchased it. I know i could do Alky to keep the IATs down, but what could I do about the coolant temp? I don't think putting in a bigger radiator will help as a friend of mine tried it and he still had high coolant temps. I think this comes gown to getting air flow to the radiator and with Procharger's architecture, I don't see how to do it. If I could solve this it would be great.
As mentioned, none of the airflow to your radiator comes from the front of the car in stock configuration. It comes up from underneath, via the airdam. Check it out. If you have altered that airdam/shroud at all, you may have cooling problems.
BOSS APPROVED!
