Those who moved radiator up and verticle.... in here
#61
mine finally, i took pix of the end caps but deleted them cuss i though they were old lol
when i get my fans i'm going to use that little extra material behind the radiator to use as a mount. the ones on the front i need to find a nut/bolt that will not take up so much space
#67
The whole point of a shroud in a puller setup is to spread the low pressure area (vacuum) over the entire surface of the radiator. If you expect air flow through the condensor, then you need to maintain that vacuum between the radiator and the condensor by sealing the edges of those 2 together.
Now in a pusher setup it is possible to make a shround around the fans so that the positive pressure will push air through the entire condensor, but you have to remember that the fans don't run at higher vehicle speeds (correct me if I'm wrong) so you end up reducing the area that the incoming air can enter the condensor. Now it may work more efficiently at higher vehicle speeds if you were to add a reverse shapped shroud over the fans so that the incoming air will get scooped and funnelled into the non-working fan openings.
Instead of a fan and a shroud, it would be a reverse shroud, fan, shroud like in the simple diagram below.
I(
)I(
#74
Chris
#77
I think it was definatly money well spent. Whole setup should be under 400 dollars for me.
Chris
#78
Sure do.
I got them from summit.
SPE-7769
I got 2 kits, 1 for upper, and 1 for lower. They make it in 24-30-36 inch lengths. I got the 30's and they are both more then long enough, 24's woulda been ok, but it can easily be cut.
It is a little more bling then i normally like, but they will server there purpose. It looks really nice, all chrome and everything. They are flexable, but when you bend them they hold there form good.
Chris
SPE-7769
Chris
#79
what are you guys mounting the bottom of these radiators too? Im deff. going to change up mine a little bit...right now I just have my AC condenser removed and moved back the radiator 3" and have a bracket holding it there...
what did u guys use to cut out the middle section that the stock air box bolts up too? A saw zaw or what?? Also, does this remove strength in the engine bay? I love the looks of it, its much much cleaer looking.
#80
i used a sawzall, i should have gotten the longer blade though as doing the last half the blade kept bending inwards inside of the support lol
like when i cut mine off i when to shack the car by holding onto the cut ends to see if it would flex or anything, mine didnt flex at all. i ended up not welding anything to tie one side to the other
