Twin Turbo Recommendations
Old 07-04-2007, 12:12 AM
ProgGod's Avatar
Default Twin Turbo Recommendations
I am building an LS6 engine, with forged internals, etc. Should produce around 500hp at the flywheel. Whats the best twin turbo charge for this engine, and where is the best place to buy it? Looking to get 750hp+ at the rear wheels.
Old 07-04-2007, 12:32 AM
firehawk123's Avatar
Gen-TT is the best place for me to get your turbo and its eazy to install , and you will get alot off power my car made 700HP 770TQ on just 10 PSI @ 4750 RPM
Old 07-04-2007, 12:42 AM
mulot30th's Avatar
but those pipes UNDER the car... that is something that I find unacceptable.
Old 07-04-2007, 11:18 AM
ProgGod's Avatar
Who is GEN TT, whats their web address? I was looking at turbo systems, are they any good?
Old 07-04-2007, 11:23 AM
mdhmi's Avatar
What type of car is this for?
Old 07-04-2007, 11:25 AM
ProgGod's Avatar
Its for an LS6 engine. Actually going in a Factory Five GTM
Old 07-04-2007, 12:41 PM
Moderator
98Aggie's Avatar
Have you purchased the GTM yet?
Your going to have to get a custom kit made in order for it to fit in a FFR GTM. You'll probablly have to end up doing mods to the frame to get everything in there. Not much room for an intercooler. I think there is a single turbo GTM out there an I think it was a custom job.
Can you get the G50 tranny built staut enough to handle over 600rwhp?
Old 07-04-2007, 02:40 PM
ProgGod's Avatar
Transmission may or may not handle the power. If it doesn't I'll either have to get it rebuilt, or get a custom tranmission built. I should have the gtm with in the next month, so I wanted to figure out what I would need to do to get a turbo on it. Figured it would have to be somewhat customized. I am hoping I can get turbos put on it in lieu of a supercharger, which would probably be an easier install.
Old 07-04-2007, 03:13 PM
mdhmi's Avatar
I think a TT F5 would be awesome. You'll definitely need a custom kit.
Where abouts are you located?
Old 07-04-2007, 10:13 PM
Hugger Z's Avatar
You should talk to Jeff Schwartz at Schwartz Extreme Performance in Illinois. He has done a few twin turbo Ultima's and some of his stuff would probably fit your GTM depending upon frame clearances. But they use the Porsche transaxle's too so the set-up would probably work for you or be pretty close.
Old 07-05-2007, 12:04 AM
ProgGod's Avatar
I am in phoenix, az. I'll have to give jeff a call and see what he can do for me. I need to make the decision now if i can fit a turbo in there, so i can build the engine for boost
Quick Reply: Twin Turbo Recommendations
