H/c Fmic Install With Pics
Old 11-28-2007, 03:15 AM
Rickys S/C Z28's Avatar
Default H/c Fmic Install With Pics
i had started a thread earlier on this but cant find it so here it is, almost done!!
Old 11-28-2007, 03:20 AM
this is were im at so far i mad a few rookie moves but it getting there
Old 11-28-2007, 03:21 AM
big thanks to the guys that have helped me !!!!! and sorry there not in order
Old 11-28-2007, 03:29 AM
TT-TECH Veteran
Inspector12's Avatar
Looking good. Hope you pinned the crank.
Old 11-28-2007, 03:35 AM
navymitch12's Avatar
we didnt....you think it will be necessary at 7psi? even still if enought people think so i would not be to much harder to go back and pin it....he has the kit just a matter of pulling some belts and doing it but is it really necessary at 7psi?
Old 11-28-2007, 03:39 AM
i posted up about pinning the crank and was told that with a stock balancer i could not do it???
Old 11-28-2007, 03:54 AM
i still dont buy that ricky!
Old 11-28-2007, 04:04 AM
TT-TECH Veteran
That is not true. In your own post they posted up a picture of a stock crank pinned etc... Take a look again. https://ls1tech.com/forums/forced-induction/820708-any-line-write-ups-keying-crank-w-ati-key-kit.html
Do I think it is an absolute must but you are pushing your luck is all I am going to say if it spins you will more than likely take out your crank and you will have to pull it and have it repaired etc... The Maggie kits on the vetts use the pin kit you need for a stock balancer. A shop Like MTI will have a lot of those kits and will probably lend you one etc... If you use and ATI balancer you have to use the kit they sell that goes through the crank and has the pins sticking up etc... Good luck!
Jeff
Old 11-28-2007, 04:06 AM
yea i did a maggie on a f-body and pinned the stock crank...or at least 75% sure it was stock but either way i figured it could be done....we can knock that out in a couple min tomorrow ricky!
Old 11-28-2007, 06:37 AM
EPP
EPP's Avatar
It looks good Ricky! Bob
Old 11-28-2007, 08:00 AM
No Juice's Avatar
Looks good
What heads and cam did you go with? You may want to get a bigger crank pulley
Old 11-28-2007, 09:29 AM
618HAWK's Avatar
With the stock unit there is no key way so it needs to be pinned from the front of the crank.
Unless you are using the ATI Super Damp, it dose have a key way and is pinned from the side.
Save yourself major problmes and upgrade to the 8 rib drive with the ATI Super Dampaner if you can. You wont be sorry!
Old 11-28-2007, 06:46 PM
Originally Posted by Inspector12
That is not true. In your own post they posted up a picture of a stock crank pinned etc... Take a look again. https://ls1tech.com/forums/showthread.php?t=820708
Jeff
wow thanks man i fell like an stupid! i did not go back and check it after the guy said it could not be done i will get this going today and thank very much!!!
thanks man!!!!
Old 11-28-2007, 06:49 PM
Originally Posted by No Juice
Looks good
i have stocl 6.0 heads with DG springs, and i went with EPP blower cam also 60lbs injectors, LS6 intake, LTand a and true dubble roller timeing chane and an slp oil pump, i want to stay were im at for know because im on the stock bottom end but thanks any way
Old 11-28-2007, 06:52 PM
Jake@EPP's Avatar
Ricky, you can use a Vette/GTO pin kit for the factory balancer.
It looks VERY nice on there!
Old 11-28-2007, 07:24 PM
ok thanks but can i use the ATI kit that yall sell?
Old 11-28-2007, 09:52 PM
Reject's Avatar
very nice pix, hope you get it done super fast with results
Old 11-28-2007, 10:33 PM
Restricted User
Smokin87TA's Avatar
looks likes its coming along nicely. Good luck getting it all buttoned up. Tim
Old 11-29-2007, 01:01 AM
thanks guys for the kind word! But today was no good seems like every thing i touched went wrong so i had to stop but i think tomorrow will be better maybe i wont be my self
Quick Reply: H/c Fmic Install With Pics
