99 Trans Am sitting for 4 years
I'm looking for a little guidance in getting my 99 Trans Am back on the road after sitting for about 4 years.
I had some issues with storage a few years back and unfortunately had to dump the car at my in-laws. I didn't plan on keeping it there so I never prepped it for storage and now its got some expected fuel problems.
The last time I tried to start it, which was over a year ago, it would run off of starter fluid, but it wasn't getting fuel.
After 4 years of sitting, the gas is obviously bad (as are all the other fluids) but I don't really even know where to start. I'm guessing the fuel pump is shot, but I'd love to get a little help on how to start diagnosing and fixing the problems.
Would the first step be to drain the tank and put some fresh gas in? Or take off the fuel filter and see if the gas is flowing?
I'm far from a mechanic so some detailed help or links to how-to's would be great.
Thanks in advance for any help you guys can give!
I don't have a pressure gauge but I hit the schrader valve out of curiousity. The gas smelled like either but surprisingly there was pressure in the rail.
I have the battery on a charger now but I don't know if it will hold a charge.
My car sat for seven years, probably wasn't fired up for the last five of them. The car only had a few gallons of gas in it while sitting. Before I fired it up the first thing I did was changee the fuel filter. When I was ready to fire it up, I dumped in some new gas with some marine grade Sta-Bil, only because it's blue in color. I popped out my fuel pressure gauge sending unit from the front of the fuel rail and attached a clear PVC hose to it with a hose barb, running into a fuel jug on the floor. I turned the key and watched the color of the fuel until it had noticeably changed color. Once I saw that I reinstalled the sending unit and attempted to start it. It didn't turn over more than a few seconds before firing up. Hope this helps.
I don't think there's a lot of fuel in the tank, but I'm not positive because the fuel gauge isn't totally accurate.
So interestingly, I slow charged the battery for a few days and put in back in the car today to see if the fuel pump would prime. Turned the ignition on and surprisingly heard it turn on. I didn't think I heard it when I tried it a year ago.
Just for the hell of it I gave it a crank and the son of a bitch fired right up, no hesitation. I shut it down immediately since I haven't put in fresh gas or changed the fuel filter yet, but it was a damn good day!
Drained the fuel today and changed the fuel filter. Put in 5 gallons of fresh 93, primed the fuel lines, and she fired right up no hesitation.
This is some of the gas that came out:
