racetronix fuel pump
my racetronix fuel pump went out on me last night and was wondering if anyone knew where i could get just the pump instead of buying the whole kit?
it is for an 02z06
thanks
it is for an 02z06
thanks
Just ordered a walbro 225 for my LT1 from one of the sponsors. They are much better than the stock pumps and don't require dropping the entire chassis to get to it if I need to
Use thunder racing, they have quick shipping and are great to deal with. The Racetronix pump is just a Walbro with an aluminum shell on it. There is a snap ring up top that you remove, then the pump slides out. Install the new one, put the snap ring back in and the wiring will hook directly back up.
Originally Posted by michael02z06
thanks, i just don't want to buy the whole kit when i just need the pump, i will try thunder racing in the morning.
Restricted User
Curious as to what the life expectancy is on these pumps. I am having a fueling problem and am wondering if my 6 month old racetronix pump is the problem or if it is electrical in nature. Sometimes the pump will prime when I turn the key and after a sec the car will die and then I can hear the pump prime again. Other times it wont prime at all.
LS1TECH Sponsor
it is for an 02z06
thanks
it is for an 02z06
thanks
Did you contact your dealer or support@racetronix.com with the details of your problem, what you have done to diagnose it and your contact info?
Racetronix Support Team
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
LS1TECH Sponsor
Please contact support@racetronix for support.
__________________
>WEB SITE<
>WEB SITE<
LS1TECH Sponsor
Originally Posted by ArcticZ28
What part of that was erroneous, exactly?
This may give some customers the impression that any Walbro pump will work which you probably know is not the case.
You are correct that Thunder Racing can supply replacement F99 pumps.
Thanks
__________________
>WEB SITE<
>WEB SITE<
Originally Posted by Racetronix
"The Racetronix pump is just a Walbro with an aluminum shell on it"
Thanks
Thanks
Well then why don't you clarify. What is the difference? Can you not just put the shell on a new Walbro?
