Moser 9" center section removal
Old 02-10-2009, 09:08 PM
JBM
JBM's Avatar
Default Moser 9" center section removal
I have to pull mine and that sum bitch is stuck. Any tricks?
Old 02-10-2009, 09:18 PM
DiabloFormula's Avatar
Screwdriver...and if it's a Iron case hold on tight!!!!!
Old 02-10-2009, 09:23 PM
JBM
JBM's Avatar
I've got the aluminum through bolt case. Dont want to gouge the case if at all possible.
Old 02-10-2009, 10:22 PM
Just be careful with it, it'll come off.
Old 02-10-2009, 11:58 PM
jetlag's Avatar
I agree...haha
Old 02-12-2009, 07:09 AM
JBM
JBM's Avatar
pita
What else ya got.
Old 02-12-2009, 07:41 AM
Fireball's Avatar
they tend to fit tight on the studs. I lift one side up with a screwdriver a touch then work a screwdriver on the other side...work it up incrementally
Old 02-12-2009, 08:06 AM
JBM
JBM's Avatar
I used RTV with no gasket. I'm trying to wedge a screwdriver between the center section and the housing, but it only digs into the center section. Hope I won't have to pound out the housing studs.
Old 02-12-2009, 08:18 AM
Fireball's Avatar
guess you sealed it up a little too good
got a junk screwdriver that you can sharpen? sounds like the problem is you're trying to drive a blunt object into a tight space...
Old 02-12-2009, 08:20 AM
Jon5212's Avatar
I hate it when that happens
Old 02-12-2009, 09:33 AM
JBM
JBM's Avatar
That's what she said.
Old 02-14-2009, 09:13 PM
Restricted User
socmguy's Avatar
Once the axles are pulled out, it should come right out right?
Old 02-14-2009, 09:16 PM
jetlag's Avatar
Right, the only thing keeping it in will be the studs.
That's what she said, also.
Old 02-14-2009, 10:12 PM
wht01ws6ta's Avatar
Yep, pull the axles, then pry it out and be ready to catch it when it gets to the end of the studs scared me both times I did it under the car but the iron case is a bit heavier than the aluminum though. Sharpening a screwdriver to get in there sounds like a good idea.
