99 ta 456 gear swap problem
Old 03-31-2009, 06:48 PM
6spd's Avatar
Default 99 ta 456 gear swap problem
a buddy wants 456 gears in his 99 ta M6 when he put the gears in, the paddle pin won't go back into place. was hopin someone could chime in with some advice. Can 456 gears go in a stock 10 bolt? I heard SLP made a seperating paddle pin but that failed so they discontinued it. I don't really know crap about rear ends.
Old 03-31-2009, 06:51 PM
01ssreda4's Avatar
do you have a pic, surely you could grind something to make it fit??
Old 03-31-2009, 07:12 PM
6spd's Avatar
no digi cam available. its that pin that sits just to the left to the gear and points to the back of the pumpkin. it would slide out towards the back of the car.
Old 04-01-2009, 10:15 AM
4U2NV-SS's Avatar
When I did mine back in the day! I just grinded as litle as possible and test fitted each time until if fit. Just grind a notch. But make sure you only do it on one side and the same way the hole id drill thru.
Old 04-01-2009, 10:28 AM
4U2NV-SS's Avatar
Here is a quick picture i make up really fast!
File Type: bmp
Old 04-01-2009, 11:41 AM
6spd's Avatar
He was really hoping not to grind that pin down. It doesn't look to tuff with that diagram.Thanks! I didn't think it was such a pain int the butt to do a gear swap.
Thanks again for the diagram
Old 04-01-2009, 02:59 PM
Sharpe's Avatar
This is the one job i personally would never do. And youre doing it after making statements like "I don't really know crap about rear ends," and "I didn't think it was such a pain int the butt to do a gear swap." So, good ******* luck getting them in there without a **** ton of gear wine.
I just Googled for you:
http://www.keliente.com/gears.htm
http://bertok.us/agreif/eaton/eatontech.htm
http://www.chevyhiperformance.com/te...all/index.html
Old 04-01-2009, 05:46 PM
FirstYrLS1Z's Avatar
pic of SLPs' torsen paddle for 4.10s'
how I had to grind down the gears to allow the center pin of an Eaton posi
even though I had to grind the gears,the removed portions are well away from the mesh contact area,as seen by the marking compound.I built this rearend in the fall of 2007,taken 3 trips to Florida from Ohio and no problem has occurred.
Old 04-01-2009, 05:55 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Question
456 IN A Stock 10-Bolt..????????
Old 04-01-2009, 06:46 PM
4.56s' in an A4,why not !
Old 04-02-2009, 09:56 AM
6spd's Avatar
I don't have anything to do with it. My mechanic buddy just asked me to post for some information. I don't know why the goober wants 456 gears, but hey, its not my car.
Thanks again for the great pics and info. I knew this was the place to go.
