Question about nicks and scratches on 9" housing
Old 12-13-2015, 07:51 PM
pontiac_boy's Avatar
Default Question about nicks and scratches on 9" housing
So long story short my rear end was taken apart for a rebuild and in the process the person (it looks to me anyway) went a little to far cutting the races out of either end of the housing. Now each end has three of four pretty deep gouges and scratches in them. Im trying to load pics but i can't get into my photo bucket account. My question is has anyone else ran into this? What did you do to fix the situation?
Old 12-13-2015, 08:22 PM
Here are some pictures. Any advice is appreciated
Size:  247.7 KBName:  IMG_1492_zpspzov0skz.jpg
Size:  291.2 KBName:  IMG_1491_zpsknfljaco.jpg
Old 12-13-2015, 09:14 PM
FirstYrLS1Z's Avatar
I've seen worse. clean up the nicks and scratches by hand with emery cloth. put a thin layer of RTV in the scratch/nick areas during assembly to prevent any rear end gear oil seepage. then you should be 'good to go'.
Old 12-14-2015, 09:23 AM
MidwestChassis2's Avatar
Like mentioned clean the areas up the best you can and make sure there is no sharp edges. When you install your new bearing make sure you use a little RTV on the seal itself. This will help it seal.
Old 12-14-2015, 03:41 PM
01ssreda4's Avatar
Dang, watch who works on your **** right? Looks like he was impatient.
Old 12-14-2015, 04:05 PM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
No kidding!! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 12-14-2015, 04:39 PM
I don't ever recall having to cut one out. Make sure to clean your entire housing out.
Old 12-14-2015, 10:13 PM
I don't want to share to much because its still kind of a fresh situation and i don't feel its right to bash on someone before they have the opportunity to make it right. I just wanted to get some opinions from guys who have been around and worked on these rear ends a time or two so i could possibly determine what a good fair fix to the situation is.
Old 12-14-2015, 11:30 PM
01ssreda4's Avatar
Good luck. Hope you get it worked out.
Old 12-16-2015, 08:18 AM
ss1
ss1's Avatar
When I took my 12-bolt apart to swap the gears, axles, and bearings I couldn't get one of the races out. I found the spacers between the backing plate and flange were left out, so when the four bolts were tightened it bent the flange outward at those four points. I used a hammer and piece of steel to straighten the housing end and the race slid right out. Not a big deal, it just took a few extra minutes to figure out the problem and solve it correctly.
I think you'll be alright anyway. Just use some silicone/RTV on both seals and you'll be good to go. Nobody will ever see it once the axles are installed.
Quick Reply: Question about nicks and scratches on 9" housing
