What actually happens when you break your 10bolt?
Old 04-29-2005, 01:18 PM
Lss1350's Avatar
Default What actually happens when you break your 10bolt?
I have a few traction mods(torque arm, sfc's, lca's) with some 315 nittos and I plan on going to the track a few times this year. What can I expect to actually break when I drop the clutch around 3,000rpm?
Isn't the assembly inside called the carrier? Is that what explodes? You dont have to replace the entire rear end after you "break" one do you?
-j
Old 04-29-2005, 01:48 PM
trackbird's Avatar
You name it, it breaks. Axles can break. The ring gear can break. The pinion gear can break. The internals of the limited slip unit can break, etc. It depends on your luck it seems. The ring and pinion or carrier usually seem to break before the axles, but that's not guarenteed either. So, it can be almost anything.
Old 04-29-2005, 04:18 PM
JC93Z's Avatar
You don't drive anymore.....
Old 04-29-2005, 10:27 PM
waltsfastz's Avatar
Ive seen 3 in person that has broke. The first 2 broke the ring/ pinion gears. the last one shelled 3 spider gears.
Old 04-30-2005, 01:01 PM
Lss1350's Avatar
So can it be "rebuilt" for a decent price or is a 12-bolt just as much? Also does a T/A girdle really do anything?
-j
Old 04-30-2005, 01:12 PM
WJ SOM SS's Avatar
Usually, all parts inside have to be replaced, because broken metal pieces floating around inside housing ruin everything--gearset, limited slip carrier, and all bearings. If you just break a end off a axle, you may get away w/replacing less. Also, if the end shears off the carrier where axle enters either side, you may salvage the ring and pinion, axles and some bearings. Used or new ebay parts: $4-600, plus labor, unless you can do it yourself... WJ
Old 05-01-2005, 09:27 PM
red95ssclone's Avatar
Im on my 3rd ring and pinion . The times that it has broken, i ripped teeth off of the ring gear and the pinion gear. What happens with the 10 bolt most of the time is that the housing flexes under torque and keeps the ring and pinion from meshing completely, kinda like striping a bolt. One of my friends though it would be funny to drive on a broken gear because he was getting a 12 bolt, the axle completely locked up and his car sat in the middle of the road waiting for a tow truck. All of the time i have broken mine it just sounds like hell, sometimes the car jerks under throttle and sometimes it just is really loud. Thats just my experience/ 2 cents
Old 05-02-2005, 01:51 PM
BBQLS1's Avatar
-j
You may break any combination of the following:
1. Ring gear
2. Pinion gear
3. axles
4. carrier/differential
5. cap bolts
Get out your 5 gallon bucket and oil cleaning stuff. It sucks.
Old 05-02-2005, 03:24 PM
Derek98z's Avatar
I broke a spider gear. I took it to a shop, had the gear removed, and drove with the rear another 2 weeks before the 9" came in! It was sloppy and clunked around a lot. I was getting real nervous there at the end though. Car handled very poorly.
Old 05-02-2005, 05:54 PM
Spenser309's Avatar
let me put it this way i had to get a tow. because every last one of the teeth on that ring gear were gone. Thank god i sheared em all of because i wouldnt of been able to move it otherwise.
Old 05-03-2005, 01:50 PM
_HAVOC_'s Avatar
both times for me the differnial broke, acutally exploded into 100's of pieces, my stock ring and pinion still look brand new.
one time it did shear an axle though.
Old 05-04-2005, 01:10 PM
sstony's Avatar
I'm going through replacing my posi right now. i just put a bunch more power to the rear wheels and some drag radials and everything else is braking. just had my tranny rebuilt and now my posi broke at the track. driving straight it was fine but giving it gas while turning and it felt like the rear was going to explode--loud clunks and and it felt like it would just let go. well i drove home from the track scared shitless that it was gonna lock up at any moment with no warning but i made it all 3 hours just fine. took the cover off and examined my ring and pinion and no big chunks missing. there were lots of small metal shavings and a few big chunks, about the size of finger nails. i'm doing the cheapest fix, which is throwing an auburn in it and hoping it doesn't crap out before too long. i'm gonna stop going to the track for a while.
Old 05-04-2005, 02:15 PM
12 Second Truck Club
white1's Avatar
My carrier broke right under the caps. When it dropped it screwed the ring and pinion. I've heard of just about every part in there breaking though.
Old 05-04-2005, 06:36 PM
SaudeKeep's Avatar
can something break without any noises or dysfunction but later on cause a bigger problem?
Last edited by SaudeKeep; 05-04-2005 at 06:36 PM. Reason: didnt mean to quote anyone specifically
Old 05-05-2005, 06:02 AM
severous01's Avatar
c-clips...but thats usually from hard turns/curvs at high speed. or doing power slides and stopping in the middle of them...donuts...stuff like that. if your rear was jacked, you'd know it. it would clank, clatter, jerk/jolt, or squeak really really badly. if it's just the clips they're only 10 bucks for each side. your calipers will likely rub the rotor or have uneven braking surfaces on the rotor/caliper/pads.
Old 05-05-2005, 04:42 PM
Spenser309's Avatar
wait nvm mind i broke the diff too. Just found out today it was cracked.
Old 05-06-2005, 10:22 PM
Spenser309's Avatar
and wait also now i found that an axle twisted. gonna go get the broken parts in a few days.
Quick Reply: What actually happens when you break your 10bolt?
