Eaton Posi OR Truetrac Limited Slip
Old 01-14-2006, 12:17 AM
01formulafromthebay's Avatar
Default Eaton Posi OR Truetrac Limited Slip
I am getting a moser 12-bolt and i called Moser and they told me truetrac was better than eaton posi. then the place where i ordered it from told me that the truetrac is noiser than the eaton posi. does anyone know if any of this is true.
Old 01-14-2006, 02:29 AM
MattZ28's Avatar
I'm very happy with my Eaton....a few of my buddies run it runnng 9s and 10s with no issues.
Old 01-14-2006, 05:34 AM
EPP
EPP's Avatar
I have sold dozens of Moser rear-ends with the Truetrak, and we also install quite a few of them. I have not noticed them being any noisier at all. My own Moser 12 bolt has the eaton in it, as I installed it nearly four years ago, back before Moser offered the 12 bolts with a Truetrak. If I had a choice, I would of gone with the Truetrak. Bob
Old 01-14-2006, 10:28 AM
NHRATA01's Avatar
Yeah, everyone seems to be liking the truetrac - as long as its durable for drag racing, I'd have no problem going with it.
I've been running an Eaton in my 12 bolt for 3 seasons now, and its working fine. Only negative is it clunks on tight turns (and I tried 1, then 2 tubes of the posi additive with no effect). As long as it doesn't do the one wheel peel at the track I don't care. It is rebuildable when the clutches wear out. But I probably will switch to the True Trac when it wears out if the good reviews keep pouring in.
Old 01-15-2006, 01:24 PM
roy
roy's Avatar
I believe the Eaton uses cone clutches which = no rebuild when worn out.
Where as the trutrac has clutch plates and is rebuildable
Old 01-15-2006, 02:04 PM
Thanks for the info guys. I should be getting my Moser 12-bolt soon it is gioing to be a trutrac with 30 spline and 4.11. I will see how it goes.
Old 01-15-2006, 06:44 PM
ChiTownHustler's Avatar
Got things a bit confused there, Eaton has clutch plates and is rebuildable, Auburn std. series had cone clutches, and the TrueTrac is NO clutch plates just 2 worm gears like a torsen diff
Old 01-19-2006, 08:38 AM
JRracing's Avatar
Trutrak here and it is not noisy at all. I'm glad I got it instead of a locker.
Old 01-19-2006, 05:35 PM
FAST FREDDY's Avatar
this is incorrect the eaton can be rebuilt. you get your choice of 400#, 600# or 800# springs. a auburn posi cannot be rebuilt. not sure about a true trac though
Old 01-19-2006, 10:01 PM
tillery's Avatar
tru-trac here, the noise I get are from the richmond gears.
Old 01-19-2006, 11:48 PM
CRL 01 SS's Avatar
TrueTrac here and I'm very happy with it. Doesn't make any noise at all.
Old 02-01-2006, 08:37 PM
z-ya's Avatar
I think 12 bolt trutracs have 3 pinions per side not 2 .
Quick Reply: Eaton Posi OR Truetrac Limited Slip
