what is truetrac?
Old 07-23-2007, 01:19 PM
candyblueta's Avatar
Default what is truetrac?
what is it?
Old 07-23-2007, 01:23 PM
brad8266's Avatar
Its a POSI rear differential, it seems to be the strongest POSI out there.
Old 07-23-2007, 01:41 PM
99blancoSS's Avatar
gear driven posi as opposed to clutches
Old 07-23-2007, 02:02 PM
LSGunZ28's Avatar
i believe its very similar to a Tosen diff.
It uses worm gears instead of clutches or cones
http://www.reiderracing.com/truetrac.htm
Old 07-24-2007, 05:34 AM
EPP
EPP's Avatar
Smile
* Smooth operation
* Performs open until needed
* Fully automatic limited slip
The Detroit Truetrac was the first helical gear differential ever introduced into the automotive aftermarket as an Eaton brand. It remains the leading helical gear-type limited slip differential in the industry. Detroit Truetrac's proven helical gear design eliminates the need for wearable parts, resulting in maintenance free traction. Recognized not only for its toughness but also it’s smooth and quiet operation.
Engineered to work efficiently in front and rear axles, semi-floating (C-clip axles) and transfer cases. Power transfer is so smooth, it literally goes unnoticed by the driver - even in front wheel drive axles.
Proven design, low cost and effective performance, all make the Detroit Truetrac limited slip differential the ideal choice for a wide variety of vehicle applications. No maintenance - Just Traction!
Old 07-24-2007, 02:56 PM
Internet Mechanic
BlackScreaminMachine's Avatar
They Suck, and they break, just as much as any other diff.
I am on the 2nd one in my Moser 12 bolt. The 1st was set up by Moser. The 2nd set up by Eastside Perf. (a sponsor) Seems to be working fine, the 1st one was made by the original company, not Eaton. Niether Moser or Eaton will stand behind their product, but will praise how good it is.
If you go tru trac you will have the axles cut for that specific diff, if you wish to chng, you need new axles....
Old 07-24-2007, 04:11 PM
99blancoSS's Avatar
working great in my 9" from DLS and I thrash it hard
Old 07-24-2007, 04:29 PM
brad8266's Avatar
Thats cause you have a 9".
Old 07-24-2007, 07:04 PM
NumberOneSled's Avatar
Does the truetrac need posi additive or just 80/90w non-synthetic gear oil?
Old 07-24-2007, 07:13 PM
Jimmard's Avatar
Just plain gear oil. I'm running 75w90.
Old 07-24-2007, 08:06 PM
John35thSS's Avatar
I agree< I broke mine also pics are still posted.
They do not stand behind product and as for the no wearable parts BS when I took mine apart the worm gears were screwing themselves into the housing. Disposable junk.
before you buy anything get whatever anyone tell's you in writing so they don't forget their lies.
John
Old 07-25-2007, 12:56 AM
monzaz's Avatar
Default posis and true trac etc.
I can tell you everything wears and everything does break. JUST a fact.
Install is a HUGE part of how long stuff lasts just as much a size of parts. Jim
J D race.com
Old 07-25-2007, 12:44 PM
so im getting a moser 12, is truetrac the way to go?????
Old 07-25-2007, 12:55 PM
99blancoSS's Avatar
Yes
Old 07-25-2007, 01:21 PM
Internet Mechanic
FYI Tru Trac's are NON-serviceable units, if they break, your fucked. They are still the minority, so your not going to hear alot of horror stories but they are starting to pop up. Nothing is bullet proof, except maybe a 9" with a spool.
Old 07-26-2007, 10:10 AM
John35thSS's Avatar
NO
I have 3 12 bolt posi, with the last one a strange us gear HD unit (eaton case US gear guts) still in car.
The first a torqueline was one wheel peel but didnt break.
The second detroit tru-crap cracked and on dissasembly worm gears were grinding into case, so just about ready to explode.
The third strange HD still in car 2 black stripes everytime not broken yet.
If I had to do it again, S60 with a powerlock.
Did you know the moser is not a bolt in, we put one in a friends car and had to change driveshaft and swaybar mounts and adapt the abs (3 channel) and lets not forget the 4 self loosening torque arm mounting bolts.
The strange 12 is a direct bolt in using all the factory parts you just have to butcher the ABS harness like the moser 12, only problem is its still a 12 bolt.
The S60 is a direct bolt in (except driveshaft but they ship it with one) and the ABS is plug and play. The ring gear is larger and the available powerlock is a 4 spidergear beast of a posi that is rebuildable.
All this info only cost me 1 12 bolt, 3 gearsets, and 3 posi units
John
Old 07-26-2007, 10:25 AM
mattraypharbor's Avatar
detrioit truetrac in my dana60 and i love it.
Old 07-26-2007, 12:02 PM
who sells the direct bolt in s60???
Old 07-26-2007, 12:50 PM
99blancoSS's Avatar
Maybe you should ask John35th what kind of power levels he is talking about.
You can get the dana at DLS, not sure if Bob sells them at Exotic Performance but both are good guys. I'd talk to Bob at EPP and or DLS before making a decision. The Dana has had its issues and drawbacks as well.
Old 07-26-2007, 05:35 PM
Restricted User
Blakbird24's Avatar
My brother has a moser 9" with Tru-Trac in his '69. We don't know exactly but it's probably pushing 400 to the wheels and he runs BFG drag radials. The setup is holding up great. It's really funny too to hear the woo-woo-woo sound it makes around sharp turns.
Quick Reply: what is truetrac?
