Gen 5 Racing Tech Heads, cam, valvetrain, short block discussion
Wheels and tires for drag strip
Old 10-27-2014, 02:11 PM
jdarc1's Avatar
Default Wheels and tires for drag strip
2011 Camaro SS lowered.
Im looking for tires and rims for when I go to the track only.
I currently run P Zero 20 inch for the street but am looking for a wheel and tire setup that I can drive to the track. I want to change the tires and then drive to the track and remove when I get home later.
Does anyone know which rim will fit if I go to an 18 and which tire is best.
I was looking at MT's but not sure. Im more concerned about the rim fitting over the Brembo in the back.
Thanks
Old 10-27-2014, 04:57 PM
motion427's Avatar
I run 17" Welds RT-S series on mine. clears the Brembo's. Just need to zip tie your hand brake cable's to gain extra clearance.And check the clearance between the wheel and the lower arms.With a fast 60 ft,the wheel may hit the arm.
You can go with 18"s aswell.
Old 10-28-2014, 01:20 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Race Star 18x10.5, polished or dark
Corvette C6 replica 18x9.5 40mm offset
Both are a direct fit.
18x9.5 ZR1 replica on my car:
Race Star 18x10.5 rear, 17x7 front, pic from web (TPower's car):
Old 10-28-2014, 01:41 PM
jdarc1's Avatar
@Pro stock John,
Thanks alot this really helped, wasn't getting many responses. Spoke to Race Star and they have exactly what I want.
Thaks again
Old 10-29-2014, 02:47 PM
LS1Tech Co-Founder
coo, i'm a dealer for them too.
Old 10-31-2014, 03:19 PM
jdarc1's Avatar
Default @prostock john
John, what tires are you running on your star racing rims. I got the 18x10.5. I'm looking at Mt p305/35r18's
Old 11-01-2014, 04:02 PM
LS1Tech Co-Founder
For the rear I am running 305/45R18 Nitto NT05R.
The 35's you are talking about sound kinda short no?
Old 01-22-2015, 11:07 AM
RooRnZ28's Avatar
Will any corvette replica wheel work for the rears of a ZL1? I was looking at these:
http://www.oewheelsllc.com/Wheels_3/...2#.VMEuH0fF9AI
not sure if i need 9.5" or 10.5"
Old 01-22-2015, 03:04 PM
LS1Tech Co-Founder
I created a sticky about drag wheels, still adding to it:
http://www.camaro5.com/forums/showth...68#post8186368
Old 01-23-2015, 10:54 AM
RooRnZ28's Avatar
Thanks for the link. Looks like the ones i posted wont fit due to the 56mm offset. Too bad cause they were on sale...
Old 01-24-2015, 01:14 PM
LS1Tech Co-Founder
56mm will require at least a 5mm spacer.
Old 06-08-2017, 08:32 PM
HSP22's Avatar
305/45R18 Nitto NT05R. For my rear .
Old 12-30-2017, 10:44 AM
jbeane's Avatar
is it possible to fit a 15" on the rear of a 5th gen?
whats it take to do it?
car in question is a 2010 ss L99auto
Quick Reply: Wheels and tires for drag strip
