General LSX Automobile Discussion Non-technical LSX related topics.
ls1 to 5.3. do they share the same oil pump and timing cover?
Old 09-27-2014, 06:24 PM
stock400whp's Avatar
Default ls1 to 5.3. do they share the same oil pump and timing cover?
Swapping a 5.3 on my ws6 and stripping down the ls1. I know Ill be using all the front accessory as well as my crank pulley. Ill also be using the fbody pick up and oil pan w/ the oil dip stick.
but what about the oil pump or timing cover/chain and all? can I just use the 5.3?
Old 09-30-2014, 01:54 PM
slowpoke96z28's Avatar
What 5.3 is it? Gen 3 will, Gen 4 and up are a little different.
Old 09-30-2014, 04:19 PM
its a 2006 so gen 4?
Old 10-01-2014, 07:18 AM
MuhThugga's Avatar
Does it have knock sensors in the valley cover?
I think that's a year that GM started switching over to Gen IV everything, so you could have either one depending on what the engine came out of. If it is a Gen IV, make sure you don't have a 58x reluctor on the crank.
Old 10-02-2014, 01:59 AM
Yea knock sensor is in the valley cover.
I looked at the reluctor sensor. is that the one by the starter?
mines black so it should be the right 24 that i need
Old 10-02-2014, 10:11 AM
MuhThugga's Avatar
If the knock sensors are in the valley cover, then it is a Gen III block and you are good to go. All Gen III engines are 24x. Not all Gen IV engines are 58x.
Old 10-02-2014, 08:44 PM
thanks. so i can keep my timing chain cover and oil pump correct?
just need to transfer my pick up tube and oil pan. w/ front accesory
Old 10-03-2014, 08:04 AM
MuhThugga's Avatar
You can.
You can also replace them since you are in there. Your call.
Also, you can keep those things regardless of Gen III or Gen IV. There are other things that would need to be done if you had a Gen IV motor, but since you don't, happy motoring.
Old 10-03-2014, 12:23 PM
Awesome thank you.
Ya I'll be keeping them but I'll be porting the oil pump before I put it in the car.
Engine has 36k really Clean. Came out of a show truck.
Thanks again for the info.
Old 10-11-2014, 03:43 PM
This an iron 5.3L?
Old 10-16-2014, 09:38 PM
Originally Posted by slowpoke96z28
This an iron 5.3L?
yes lm7.
I already started the swap over. aside from alternator mount hole(which i will relocate anyways) everything seems like a bolt and go so far.
Quick Reply: ls1 to 5.3. do they share the same oil pump and timing cover?
