General LSX Automobile Discussion Non-technical LSX related topics.
Free mods..
Old 04-21-2007, 07:45 AM
12 Second Truck Club
Heath's Avatar
Default Free mods..
I'm heading to the track tomorrow, and I was just wondering if there are any free mods I could do before I went. I have a 98 Z28 A4.
Old 04-21-2007, 07:49 AM
six_string_wiz's Avatar
What if any have u done already?The tb bypass is easy as hell.I took off my ac belt.(not sure if that really did anything).Did u fresh up all your fluids?
Old 04-21-2007, 07:51 AM
Cold air cutout
Tb bypass
Maf screen removal
Old 04-21-2007, 08:01 AM
FU_I_AM_UltraZ's Avatar
i've seen someone take their p/s belt off and put a smaller serp. belt on and took off .3 in the 1/4. i haven't tried it out but am thinking about it.
also, on the show horsepower tv (i think) they had a SS M6 they did a before and after chasis dyno and gained 8rwhp just by swapping out the engine, tranny and diff. oils with royal purple. not sure what the tq. gain was. not bad. i should have donw that before i had my car dynoed.
if you have a hack saw, you can cut the middle of your MAF ends out and with a tool of your choice (dremel) grind the sides down to smoothen it out completely and hone it if you have access. its worth 1rwhp.
Heath's Avatar
Right now the only thing done to the car is that I cut the factory muffler off the other night and replaced it with a turndown.
Old 04-21-2007, 08:02 AM
Heath's Avatar
I dyno'd my truck last week with a belt that bypassed the P/S and A/C and it was worth 11hp..
Old 04-21-2007, 08:06 AM
U gotta spend a couple $$ and get the lid mod.If anything go "hands on" and do the free coldair mod.The Throttlebody Bypass is a good choice too.If you use the search feature with the words "free mods list"i think they stickied this topic.Goodluck at the track.
Old 04-21-2007, 08:07 AM
mcamarols1's Avatar
dont take the maf screen off leave it stock
tb bypass, free ram air, and a cut-out ftw
fresh fluids, good fuel, and the driver mod
Old 04-21-2007, 08:10 AM
Old 04-21-2007, 08:23 AM
Administrator
unit213's Avatar
TB bump stop mod is worthwile.
TB bypass is a waste of time and is worthless IMO.
Old 04-21-2007, 08:27 AM
I guess i have to slightly hijack and feel like a rookie,i have to ask>Whats the tb bsm?
Old 04-21-2007, 08:30 AM
subtlez28's Avatar
Really, That is VERY hard to believe...
Old 04-21-2007, 08:45 AM
Mikerace15's Avatar
Take off your lid/maf and look at the throttle body blade while moving it to wot. On some cars the blade dosn't go to 100% wot because the bump stop is too high. If you cant get 100% wot get out the dremel and grind down the bump stop till you can.
Old 04-21-2007, 08:58 AM
Originally Posted by Mikerace15
Take off your lid/maf and look at the throttle body blade while moving it to wot. On some cars the blade dosn't go to 100% wot because the bump stop has too high. If you cant get 100% wot get out the dremel and grind down the bump stop till you can.
My bad,I spaced that off.I was gonna do that, but i heard its best done with autotap.Thanks for the info.
Old 04-21-2007, 09:45 AM
NoSlowSS's Avatar
Rather than cramming in last minute mods and risk messing something up in haste, I'd focus on making sure the car is in top shape. Check your spark plugs and make sure they are in good shape and correctly gapped... maybe even replace them if you've got a little extra cash laying around. Make sure tire pressures are good and maybe search to see what most guys run for psi on street tires to get a good launch.
I'd plan on changing fluids either before or after you're done running. Changing before may give a slight advantage and would maybe offer some extra protection. Changing after would get the extra crap out of those systems caused by running it hard. This is probably just being picky anyway since you're running a stock car and not doing anything beyond what it was intended to do.
You may also want to simply run it as it is and establish a baseline of what the car can do now... so you can more accurately judge what if any impact your next round of mods makes. Doing something in haste now (maybe incorrectly) could actually hurt performance rather than help and you wouldn't know unless you had a baseline.
Old 04-21-2007, 09:52 AM
2000badbird's Avatar
dont mess with the maf maybe descreen it but thats is as far as i would go. port your trottle body. bypass the tb coolant lines helps keep the intake charge a lil cooler. maybe modify your air box but if you do so you will constantly be changing or cleaning your air filter. free mods arent really worth it unless you are on an all out search for hp.
Old 04-21-2007, 11:49 AM
02silvaZ's Avatar
port and polish t/b & MAF, free ram air mod, t/b coolant bypass, thats about it
Old 04-21-2007, 04:18 PM
mcamarols1's Avatar
screwing w/ the maf will make the car lean out, and as he mods more and gets around to needing a tune the maf tables are screwed up cause the maf flows more than what its reading, the stock maf is good for 450-500hp, the screen offers the extra protection. do, however port ur TB and do the TB bsm, as for the TB bypass u might not feel any gain but why would u want 200F' coolant heating up air going into ur engine?? do it for the denser air charge. if its .5 hp, so what, its a cheap mod, do it.
also like it was said b4 make sure ur car is ready for abuse. if u take care of her properlly shell put a smile on u everytime. change the oil (i use GC 0w-30) get some fresh plugs(i use tr55) fresh wires(if needed) etc ect ect. the list goes on forever. do it for peace of mind, hell do it if ur bored.
Old 04-21-2007, 04:21 PM
mcamarols1's Avatar
Old 04-21-2007, 09:24 PM
Fibbado's Avatar
The #1 free mod... is the driver mod...
