98 ls1 problems
98 ls1 problems
I have a ls1 head and cam stock bottom end 98 Vette. THe car has always used a little oil, but with time it seems to be huffing more and more. It some times huffs when when idles and huffs when I get on it at higher rpm. The car put down good power (440 rwhp). I do not have cats on the car. What could this be?
Originally Posted by 98Camarod
Are you talking about smoke coming out of a breather cap? How much oil are we talking here? I see your tryin to squeeze 1 extra hp out of 439
No breather, huffing out the tail pipe, it doesnt do it right away at idle but after a drive or been running for a while and at load in hight rpm. I have not done the zo6 pcv mod yet but have triied a breather and it seemed to not change, and I do have a catch can on the system but that doesnt seem to do what its supposed to do.
Oh sorry about the 1 hp white lie, just easier to type ( being lazy)
i have 2000 t/a and it does same thing i found that my car eats oil threw the pcv system put a catch can on it should help i took my intake off and there was oil all over inside of it from the pcv system sucking the oil threw
If its coming out of the tail pipe then its getting in the combustion chamber some how. My guess would be valve seals or rings. If it gets enough oil in there to blow a puff of smoke all the way through the exhaust there has to be enough oil in there to make that large amount of smoke. I really do not think it is your pcv system messing with you. Do a compression test and see where that leads you.
