Gutting Cats
Old 02-22-2010, 04:07 PM
93z28lt1's Avatar
Exclamation Gutting Cats
Well im planning on gutting my cats because they are rattling like crazy. Whats the easiest way to get this done? Should i just gut them and leave it hollow inside or run a pipe through it. If so what size pipe would run through the original cat?
Old 02-22-2010, 04:19 PM
LS6427's Avatar
Originally Posted by 93z28lt1
Well im planning on gutting my cats because they are rattling like crazy. Whats the easiest way to get this done? Should i just gut them and leave it hollow inside or run a pipe through it. I live in Missouri and its a 2500 dollar fine if i get busted.
Well don't think gutting them and leaving the hollow cat on there will fool anyone. Here in Florida the troopers have laser temp guages. They kneel down, point it at the exhaust pipe, then the hit the cat with it. If the temp at the cat is the same as the exhaust pipe....your busted.
Get new cats if you don't want to risk a fine.
Old 02-22-2010, 04:21 PM
twelver12's Avatar
sounds like its not worth gettin busted over, just replace them
Old 02-22-2010, 04:25 PM
...with cheese.
Armageddon's Avatar
There's a guy on this board that pays good money for old converters. Sell him your old ones and put that money toward the cost of replacements.
Old 02-22-2010, 04:48 PM
fknsmshn's Avatar
Buy new. Gutting CATs hurts performance anyways.
Old 02-22-2010, 05:04 PM
stburgpete's Avatar
Question? How does gutting the cat hurt performance? I see alot of people on here removing them when they up grade. Wouldn't this be some what the same?
Old 02-22-2010, 05:29 PM
fknsmshn's Avatar
Gutting them is not the same as removing them. When you remove the CAT, you replace with a piece of pipe. When you do that you keep a consistant volume in your exhaust system. When you gut them, you create a low pressure spot where you loose all your exhaust velocity. Then when the exhaust has to leave the CAT it all piles up and kills flow.
Old 02-22-2010, 05:39 PM
stburgpete's Avatar
That makes sence thanks.
Old 02-22-2010, 08:06 PM
93z28lt1's Avatar
so i should run a pipe through my cats? If so what size pipe will fit through the cat?
Old 02-22-2010, 08:30 PM
fknsmshn's Avatar
I dunno that you can. If anything I guess if you gutted em and found pipe that would fit you could weld it in and be ok. Like someone said earlier, sell yours to a recycler and take the money to go get new ones. Thats the best bet, and the least hassel.
Old 02-22-2010, 09:12 PM
slo_lt1's Avatar
were in missouri? im in st.charles seems like around here cops dont really mind i havnt had a problem with any of my cars that didnt have cats.
Old 02-22-2010, 10:05 PM
93z28lt1's Avatar
what size pipe should i run through the original cat?
