No dash lights & no courtesy lamps
Well long story short car was invovlved in an accident most damage was on the oil pan and k member all that was replaced and I also had to replace the steering column. Once I replaced the steering the column I was able to start the car and the lights and everything was working perfectly fine. Next day took car out for a drive and the dash lights that are supposed to come on when I turn on my courtesy lamps do not come on. Also the tail lights only come on when I press the brake. I keep replacing the fuse for the tail lamps and it keeps burning one after another within seconds any ideas? I tried replacing the headlight switch and it does the same thing. Also my foglights are not working. All this occurred at once. Im stumped on this one.
What did you hit?
But I'd pull all the underdash panels back off and start inspecting the wiring. See if you didn't get something pinched when replacing the steering column, or shoot a screw through some wires.
Well long story but I lost control and landed on top of a trailer full of wood and trash. Just bunk of junk. The front bumper and k member took the hit. Weird thing was that when I replaced the steering column afterwards everything was still working fine. I'm stuck like chuck on this one. I hate electrical things.
Save the manuals!
Did any of the lamps get damaged? You might try taking out all of the front and rear parking lamps and see if that helps the problem. A bulb could blow and cause a short. Taking them out will confirm if you need to trace the lines or not for the short.
None of the lamps got damaged except for 1 foglight which I replaced. And no nothing like that let's jus say I was at a friends house when I left I got on it and list control hit a curb and car landed on top of a small trash hauling trailer.
Ok great news everyone I found my problem. One of my ballats from my hids got damaged and it seems like the ballast was touching the chassis and it was basically grounding it causing my short. Most of my damage was on the bumper and K member. I knew it had to be something simple because the bumper pad didnt even break much.
