Changing oil pressure sending unit in 4th Gen without removing the intake
Old 07-26-2014, 06:35 AM
LSX14's Avatar
Default Changing oil pressure sending unit in 4th Gen without removing the intake
Hey guys. I had to change my Oil Pressure Sending Unit yesterday and did it WITHOUT removing the intake many in my 6.0 swapped Trans Am. I made a short vid since I couldnt really find anything helpful other than (its maybe possible). Hope this helps someone out!.
Old 07-27-2014, 07:34 AM
Save the manuals!
wssix99's Avatar
Excellent thread and video. A++
I wish I had this information before I tore up my arms doing this the other year: https://ls1tech.com/forums/general-m...ding-unit.html
I do have ogre hands and mongoid arms... and they have permanent scars (from the cowl screws) to prove that I switched out this part.
The patented LSX14-left-handed-connector-clip-reach-around move would have saved me.
Save the manuals!
wssix99's Avatar
Sticky!
Old 07-27-2014, 04:11 PM
dailydriver's Avatar
CONGRATS!!
But, you MUST HAVE tiny hands and arms AND NO emissions equipment at all on your ride.
Old 07-28-2014, 05:10 PM
idahoz28's Avatar
Im not so worried about removing the sending unit... Im worried that after I do I won't be able to put the new one in..
Old 07-28-2014, 05:48 PM
Save the manuals!
wssix99's Avatar
The hardest part is getting the electrical connector off. As long as you have the right socket and a descent ratchet/extension, getting the sensor in and out is a piece of cake.
Didn't it look easy on the video?
Old 07-29-2014, 07:01 AM
LSX14's Avatar
I'm not jacked or anything. Just average build I guess you could say. It's all about the maneuvering haha. The hardest part was the clip honestly. And then lining the new sending unit up blind. You can feel the spot though if you really stretch to get down to the block with your finger. You have to ghost it either way but its not that bad TBH.
Old 07-29-2014, 07:04 AM
LSX14's Avatar
Originally Posted by dailydriver
CONGRATS!!
No emissions stuff, but you should be able to get around it without any trouble. I'd be more concerned with the AC hard lines up top but It should be plenty feasible.
Old 07-29-2014, 07:13 PM
Yes, I guess I can also call what I have to do to get the passenger side plugs into the heads, with factory manifolds and ALL emissions equipment still working, "ghosting them".
Old 07-29-2014, 08:12 PM
LSX14's Avatar
Been there, done that. Theres a reason all that ***** gone from my car now. LOL!
Old 09-09-2014, 10:05 PM
SSx2James's Avatar
so u replaced the sending unit because ur oil low light came on even though it was full? i have a 2000 camaro SS that just had the oil changed and the low oil light came on. other than the light coming on does this have to be replaced, will it hurt just to disconnect? a repair shop wants to remove intake and charge me for all that labor. thx
Quick Reply: Changing oil pressure sending unit in 4th Gen without removing the intake
