High Pitch Whine
Old 06-15-2006, 03:28 PM
Zymosis's Avatar
Default High Pitch Whine
I started to notice a high pitch wine (very consistant sound) comming from the passenger side. It does not sound like valve train noise, and I cannot seem to figure out where its coming from. It sounds like a super charger whine to some degree, but last time I checked I don't have one of those
(I do not have AIR system so it is not a check valve)
Old 06-15-2006, 07:24 PM
Zymosis's Avatar
Nobody has a clue?
Old 06-15-2006, 10:18 PM
DamonNC's Avatar
Could be your pulley
Old 06-16-2006, 12:49 AM
sixvi6-camaro's Avatar
Mine started to whine when I put in a gatorback belt. With a standard belt it was quiet.
Mabey check the power steering fluid? does it get louder when you put a load on the power steering by turning the wheel?
Or mabey alternator?
Old 06-16-2006, 06:50 AM
Zymosis's Avatar
To be honest, after listening to it and talking to alot of people, it sounds like a 'high voltage leak' almost. The sound is seems to be comming from a coil. It reminds of the sound you get when a TV is on but there is no signal. Only a little louder / more noticable.
Power steering fluid is fine, there is no difference in sound by turning the wheels. I put my head by all of the pullies and it is not coming from there.
Old 06-16-2006, 01:25 PM
SGT637's Avatar
Maybe your AIR pump.
Old 06-16-2006, 11:39 PM
Zymosis's Avatar
Come on man, first post says I dont have the AIR system. Second the pump is on the drivers side.
Old 06-16-2006, 11:51 PM
Marc '99T/A's Avatar
Damn...beat me to it!
Old 06-17-2006, 08:30 AM
SGT637's Avatar
Ok..........Next time I will read all the way to the bottom.
Old 06-18-2006, 11:02 AM
Zymosis's Avatar
TTT for the day.
Old 06-18-2006, 12:02 PM
patSS/00's Avatar
I've also heard this a few times. Really high pitched, varies with rpm, only when fully warmed up. But then the next time I drove the car it would be gone. Maybe from the egr valve? I haven't heard it since !egr. Or maybe the system that vents gas vapor into the intake?
Old 06-18-2006, 07:50 PM
Zymosis's Avatar
I do not have EGR either.
