Brakes Squeak
Old 07-31-2006, 11:49 AM
Automaticfastic's Avatar
Default Brakes Squeak
Just changed the pads and now they sqeak. Is it because I didnt rotate the rotars? thanx for any help
Old 07-31-2006, 11:53 AM
jmm98LS1's Avatar
Did you lubricate all the contact points with caliper grease? Never just slap pads in dry.
Old 07-31-2006, 12:20 PM
shouldaboughttheZ's Avatar
and what kind of pads did you use? The cheap ones always squeak.
Old 07-31-2006, 01:18 PM
ksuburban's Avatar
junk pads with non-machined rotors are gona squeek
Old 07-31-2006, 02:36 PM
Default Thanx
ya used cheap pads! I think they are duralast or something. I dunno mechanic put in the pads so im not sure if he lubed all the contact points!? But anyways I guess the worst is that its an anoing sound and I guess maybe i might screw up some rotors!? hopefully when the time comes I can just do the whole brake set-up. thanx for the help guys
Old 07-31-2006, 03:36 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
IDK man, I lubed all my contact points, used duralast gold pads and rotors, and I still get a squeak everyonce and a while.
Old 07-31-2006, 06:00 PM
Abidar's Avatar
I used hawks hps pads and brembo blanks. My brakes squeak every now and then but it's worth it as they stop sooooooo much better than stock
Old 08-01-2006, 01:37 AM
2002_Z28_Six_Speed's Avatar
I used some brakes which said Premium on a black cardboard box from O'Relieys. My car sounds like a rats' nest braking or not. Don't get them. Will post name if I remember.
Old 08-01-2006, 10:45 AM
01WS6er's Avatar
Just a thought. I have champed the edges of my pads before to get them to quit squeaking. Remove the pads and take a grinder or similar and cut a 45 degree edge on the edge of the pad material. This causes the pad and rotor contact to have a slight angles egde on them when the pads are engaged. I do this on all my brake jobs I do and have NO noise from. This also does not effect braking either (you are not removing that much pad material). I hope this is not confusing.
Old 08-01-2006, 01:12 PM
Default .
when you say edge you mean the corner edge! That sounds good enough. Ill try to give that a try serously if these dont stop sqeaking after another week or so. For some reason there getting a little better it still sqeaks but in less part of the braking power if that makes cents. Thanx for everyones advice!
Old 08-01-2006, 01:25 PM
LS1Aggie09's Avatar
not to hijack but if you turn the rotors without changing anything else, should you still grease them up?
Old 08-01-2006, 02:14 PM
keliente's Avatar
Grease should never come into contact with the brake rotor...
Old 08-01-2006, 02:48 PM
01WS6er's Avatar
Yes I mean to cut the corner of the pad, not the backing metal part. I also use anti-seize/grease on the back of the pad also.
It your rotor wer not turn they may have a glaze on them causing some squeak.
