Oficcially Aggravated!!!!!
ok i changed my plugs changed my wires got a new pcv vaccum lines car is still fucked up dont know what to do. what do yall suggest that i do? car runs like ***, just bogs out or sputters ive tried everything dont wat else to try can someone plz give me some encouragement!!
^^i agree, you cant just go replacing things thats going to make a big hole in your wallet.What i suggest its try to get a scanner also just check for basic things like, if wire are on correct,no bad grounds,clean fuel filter.
If you have a timing light, You can hook it up to your battery and then hook it up to each individual spark plug and pull the trigger and see if each plug is firing. Just an idea.
no i havent done that since i last seafoamed my car in april or may!! i think i should try that and see what the outcome of it is. i just wanna drive it sucks breaking down all the time... IMO
Same thing was happening to me and when I hooked it up to the computer, it was telling me that it was the O2 sensors. I bought the sensors and took it to my cousin's shop so he could replace them. He took a look at it and ended up being the damn fuel pump. I learned not to always trust diagnostics results more than a good mechanic.
