Low coolant light stays on...
Old 11-24-2007, 04:02 PM
Ehatcher's Avatar
Default Low coolant light stays on...
My low coolant light stays on and i checked the radiator ... and everything that has to do with coolant is full. i dont know what the deal is. it didnt start doing it till it got cold outside
Old 11-24-2007, 06:00 PM
2001NBMZ28's Avatar
Could just be the sensor, they go bad all the time. My car doesn't have one, think GM took them off our cars starting with the 00 model, some people just disconnect it to keep the light off.
Old 11-24-2007, 06:09 PM
FrYd-RyS's Avatar
same problem with mine. i got a new one and it turned off for a while. but now it intermittently goes onand off sorta weird
Old 11-25-2007, 02:17 AM
haacer's Avatar
Good info on the low coolant sensor here: http://shbox.com/1/4th_gen_tech2.html#low_coolant_lamp
Picture of location here: http://shbox.com/1/low_coolant2.jpg
Both apply to an LT1 car, but I'm sure the location is similar.
Old 11-25-2007, 09:11 PM
kdoublep's Avatar
I had same problem in my 98 TA. Unplugged sensor and cleaned it. Has not come on since I did this over 1 year ago. Or you can disconnect as advised.
Old 11-26-2007, 01:06 PM
conde'strans's Avatar
or just try resetting it by disconnecting the battery for about 15 secs/just might work
Old 11-27-2007, 10:05 AM
pjb
pjb's Avatar
mine ended up being PS fluid in the cooling system from leaking PS cooler. PS fluid contamination gunked up the coolant sensor. do a search to get full story/fix.
Old 11-30-2007, 12:15 PM
'99DeadulusWS6's Avatar
Ended up being Oil in the Coolant gunking up the sensor in mine. Porus Lifter bores was the cause... GM picked up the tab for a new block in the end but a pain in the *** to say the least.
Old 11-30-2007, 12:18 PM
pjb
pjb's Avatar
wouldn't the lifter bores be in the cylinder heads?
Old 11-30-2007, 12:44 PM
FiredUpZ28's Avatar
dex cool likes to gunk up on its own too. Sensor is a common problem
Lifter bores are in the block.
Old 11-30-2007, 05:39 PM
SSkillz's Avatar
Sensor always goes out mine been out for the longest!
Quick Reply: Low coolant light stays on...
