annoying problem
Old 08-16-2008, 06:36 PM
momartin22's Avatar
Default annoying problem
i have a 99 firehawk and everytime i start the car the speedometer and the tach go all the way up then back down then my tripometer resets..i disconnected the battery and cleaned the posts and terminals and that worked fine for a while..but now it started back up...WHY???? its annoying and pisses me off any help is greatly appreciated thanks!
Old 08-16-2008, 06:59 PM
samson_420's Avatar
Wrong toppic, but ok.
It is either the voltage droping too low or there is a bad contact in the electrical system.
Old 08-16-2008, 08:09 PM
DarkCloud's Avatar
is the car cranking slow too??? chances are its time for a new battery....
Old 08-17-2008, 08:43 AM
momartin22's Avatar
no it fires right up....the battery was in it when i bought the car...optima redtop
Old 08-17-2008, 09:26 AM
LS1 HOSS's Avatar
Yeah, mine did the same thing for a few months and then one day I went out and it would barely crank. Your batterys gonna go soon. Once I put the new battery in the tachs stopped freaking out when I started it, so I knew that was it.
Old 08-17-2008, 09:39 AM
momartin22's Avatar
mine has been doing it for two years...
Old 08-18-2008, 03:48 AM
Black 99 Bird's Avatar
Take a closer look at your terminals. You already said you cleaned them once for a temp. fix. Maybe they need to be replaced.
Old 08-18-2008, 05:05 AM
Rick99TAWS6's Avatar
Common problem on the 99's, battery is on its way out and/or your power and/or ground terminal connections need cleaning up
Old 08-18-2008, 10:21 PM
samson_420's Avatar
A lot of times the cables are filled with corrosion. Even if you can not see it. Run through every thing with a voltmeter.
Old 08-20-2008, 08:53 AM
kclskgl's Avatar
When i would start my car my rpms would go to like 2200 and then fall back to 800 after like 20-30 secs. I also had a red top and just replaced it now i dont have the problem. Also i have a 1999.
Old 08-20-2008, 10:52 AM
keliente's Avatar
Replace the battery, it's a common 1999 problem. Happened to mine too and now it's gone since I changed the batt.
Old 08-26-2008, 07:36 PM
bterrill's Avatar
it happened to me 3 times on my 99 hawk, 2 times it was very cold and first time i started it in 2 weeks or so.
the other time, well, i think my battery was not charged much @ the time from playing the stereo a bit while cleaning it out.
I never had issues with it not firing up or taking longer and nothing else was every wrong with it, and like I said it's only happened 3 times since may of last year.
Old 08-26-2008, 07:49 PM
momartin22's Avatar
ah damn this car...its always something...clutch goes out...so i replaced that and the flywheel and for the hell of it threw in a 9'' BMR rear suspension and a linelock....then the motor blows up...i order a 408 and all that good ****....whats next? its a vicious cycle
