What Sensor Is This (that I broke)?
I broke a sensor while taking off my intake manifold (just going too fast). It's black, about 1" in diameter and 2" long, and it's located on the very back of the block, just left of the driver's side head (looking at the engine from the front). Any ideas?
Not being a dick. This question has been answered a ton. You should brush up on your search skilz. I just did a search for the words "broke a sensor" just in the titles and found 10 hits. Leave off the option for searching just titles and the number of hits is huge. I enjoy helping anybody on this board as long as they are willing to help themselves first. Most people just want their hand held.
HavATampa you're right normally i would have taken longer to do a search but i had 30 mins before the auto parts stores closed until monday. z16kalel -- thanks for the tip i was trying to figure out a good way of getting the manifold back on w/out breaking the sensor again
Don't worry about folks and their bitterness over the search function. Everyone knows how it is to be in a clinch and need some info. Good luck with your fix. I broke mine off the first time I pulled an intake off an LS1 and after spending 65 bucks and driving 30 miles for a new one I was very careful afterwords.
well ive had my intake off 3 times and every time i lift the intake and pull it out. you have to for many reasons. the rear 4 bolts will drag on the heads, the brake booster hose has to be snaked out. i just dont see how its possible to pull the intake straight forward out even if the oil pressure sender wasnt there.
