Alt Relocation Bracket
They sell it as a complete kit, or you can just buy parts. The only way they could get it to clear the 6.0 manifold setup is to run a smaller alternator. It still cranks out 75max amps (stock is only 100), which should be perfect for a car with no AC. I'll let them PM you, or i hit me up on a PM later today if you still haven't received anything from them.
The kit, if you buy the alternator, comes with their custom alternator pulley, and they cut you a deal on the crank pulley if you buy that at the same time as well. Good stuff!!
Reviving from the dead.........so has anyone tried the one mounted low on the passenger side where the a/c comp would be found? i'm gonna try calling them tomorrow to ask some questions.
it's a bit more than some of the others but not the most expensive and it's all top notch materials! if it works its definitely worth the extra to keep from having to mount the alt up high and i don't have the option for v'bands on my manifolds as it's a complete kit thats already high temp coated as well.
