cig lighter for electric cutout... yes/no?
Old 04-10-2009, 06:21 PM
brandon_01_ta's Avatar
Default cig lighter for electric cutout... yes/no?
got a dmh electric cutout and i think i got everything figured out as far as installing and running the wires.... just need to know if i can use the cigarette lighter for both the power and the ground? and if not then what is a good power source? thanks
Old 04-10-2009, 06:32 PM
schuby87's Avatar
That's what I did. Works great! Make sure to pull the fuse before working on it.
Old 04-10-2009, 06:45 PM
black01_WS6's Avatar
thats where mine is as well. looks great
Old 04-10-2009, 11:03 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I used the 12 volt acc plug on both my CETA and my old Z28
Old 04-11-2009, 01:47 AM
Ironxcross's Avatar
I have mine mounted in the power seat, feeding off the power and ground from the seat power (spliced in). If you don't have a power seat then just go with the option you thought of already.
Old 04-11-2009, 01:02 PM
99Hawk262's Avatar
I replaced the cigarette lighter with my switch....it was a direct fit. I then ran the wires to the power source in front of the parking brake. It always has power, but doesn't drain the battery. Works great and looks clean.
Old 04-11-2009, 01:17 PM
Soul TKR's Avatar
anybody got any pics of these installs...?
Old 04-11-2009, 09:17 PM
schuby87's Avatar
http://s38.photobucket.com/albums/e145/schuby87/Cutout/
Old 04-11-2009, 09:45 PM
DONAIMIAN's Avatar
I forgot where I wired mine into but its a keyed power source. I think I had a wire coming from behind the radio.
Old 04-11-2009, 09:56 PM
sroach20's Avatar
if you have tcs you can tap the pink wire on the asr switch.
Old 04-11-2009, 11:32 PM
RoDan's Avatar
I used the cig lighter, no issues at all. The lighter uses a lot more current than the little DC motor for the blade will.
Old 04-12-2009, 07:56 PM
well i wired my dmh cutout up to the black/orange wires today on my cigarette lighter then plugged up the cutout to test it.... u can hear the motor turn for a sec then stop and the blade twitches for a split second like its trying to open then nothing, it just stops.... what the hell is wrong?? not enough juice? somebody please help me out
Old 09-11-2009, 05:46 PM
Camaroguy's Avatar
I just installed my QTP electric cutout using the cigarette lighter Orange cable for power and using the bolt that holds on the shifter boot cover for ground. Everything seems to working as it should be.
I did notice 2 things that raises concern.
1) The switch that opens and closes the electric cutout is pretty worm. Is this normal ?
2) This cigarette lighter wire always has power to it, so the cutout is consistently under power. I thought that's what we are trying to avoid. I noticed this because my QTP switch has a amber/green light/LED at the tip of the switch, and its always on. Will this cause a problem with draining the battery ?
Has anyone else had similar symptoms ?
Old 09-11-2009, 06:46 PM
billyb's Avatar
Default here's mine
Attached Thumbnails cig lighter for electric cutout... yes/no?-car-3-1-09-new-060.jpg   cig lighter for electric cutout... yes/no?-car-480.jpg   cig lighter for electric cutout... yes/no?-car-479.jpg   cig lighter for electric cutout... yes/no?-car-482.jpg   cig lighter for electric cutout... yes/no?-car-464.jpg
cig lighter for electric cutout... yes/no?-all-pic-106.jpg
Old 09-12-2009, 02:08 PM
Camaroguy's Avatar
Update:
Moved the hot wire off the cigarette wire to the ASR pink wire. This makes more sense this way.
Old 09-12-2009, 02:10 PM
Detoxx03's Avatar
Mine is next to the TCS button
Old 09-18-2009, 08:47 PM
gillbot's Avatar
http://www.dayton-fbody.com/misc/cutout/100_1527.jpg
http://www.dayton-fbody.com/misc/cutout/100_1528.jpg
http://www.dayton-fbody.com/misc/cutout/100_1531.jpg
http://www.dayton-fbody.com/misc/cutout/100_1532.jpg
http://www.dayton-fbody.com/misc/cutout/100_1533.jpg
Old 09-21-2009, 01:30 PM
Camaroguy's Avatar
is anyone else getting LOTS of RASP around 2k - 3k RPM range ? I have long tubes with no cats and im getting all sort of RASP between that RPM range. Sounds horrible, but there after it sounds good.
Old 09-21-2009, 01:44 PM
Moderator
jimmyblue's Avatar
Mine sounds like crap down low, not rasp but a drone
that sounds like, well, open pipe.
Old 09-21-2009, 02:54 PM
PassoutWilly's Avatar
I wired mine to the little light in the cig. ashtray. You gotta have your lights on to open the switch but no big deal there. I had a ton of drone around 1800-2200 RPM's so I got a Loudmouth, much better now.
Quick Reply: cig lighter for electric cutout... yes/no?
