Spark plug gap
Old 04-11-2009, 07:22 PM
JimSwan's Avatar
Default Spark plug gap
hey, i was just wondering abut spark plug gap, in the past i never changed the gap on other engines where i did head and cam swaps, but my question is this im runin a stock bottom end ls1 with ms3 cam and tsp 5.3l 2.5 ported heads, is there any gap that i should be putting the plugs at or should i just go with the stock gap?
Old 04-11-2009, 07:48 PM
LSX Mechanic
Damian's Avatar
Since you've increased compression with your 5.3L heads, you'll need to back down the gap a little bit. If you're using TR55's, I'd go around .048 depending on your compression ratio.
For my heads/cam cars I build I like using the TR6 plug (a step colder) gapped .044. Works perfect especially for high compression engines and they never have false spark knock.
Old 04-12-2009, 02:08 PM
JimSwan's Avatar
yeah i was figuring that, im goin wit the tr 55 ix's and the ratio i belive is 10.75:1 with those heads.. thanxs for the help i wanted to double check
Old 04-12-2009, 05:45 PM
Smokin00WS6's Avatar
what is the stock gap? what would gap be for tr55?
Old 04-12-2009, 10:20 PM
JimSwan's Avatar
i believe .060
Old 04-15-2009, 07:51 AM
Mike94ZLT1's Avatar
I run TR6's gapped at .038
Old 04-15-2009, 09:58 PM
Thanks guys.
Old 04-16-2009, 05:31 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Same here
Old 04-16-2009, 08:55 AM
Originally Posted by Z28/2002
Same here
But you are gapping it at .038 becuase of your mods right. I dont think a mainly stock car would need gapped at those numbers right. All I have is a headers exhaust car when you come right down to it. So shouldnt I be higher.
Old 04-16-2009, 10:19 AM
Z28/2002's Avatar
The main reason I am running them is because I'm running nitrous. I ran them in my cam only 02 Z28(sprayed too) and it ran awesome on motor with the TR6s
You will be fine running the 55s
Quick Reply: Spark plug gap
