What am I retarded? (TB Bypass issue)
Old 04-13-2009, 08:05 AM
Nightrydass's Avatar
Question What am I retarded? (TB Bypass issue)
One coolant hose is 3/8", the other is 1/4"; i bought a 3/8" brass coupler and, obviously you can't jam that into the 1/4 hose. When i tried, for the hell of it, to use the 1/4 brass fitting it started to leak a little even after i taped the joint up. Dio they make a 3/8" - 1/4" Brass coupler? Now i have to hose out my engine bay b/c some coolant leaked out and now it smells. lol.
I have also been thinking how "worth while" this mod is. I have SLP's fan switch which is ALWAYS turn to the low setting when i jump into the car. SO there is a steady stream of air already cooling the motors and what not. Being that i have a black car anyways, would the TB get heatsoaked no matter what? Does it really make power? I don't want to have to deal with a drippy coolant line for .5rwhp.
Old 04-13-2009, 08:12 AM
shiv15's Avatar
I got 5/16" fuel line hose. About 2 feet worth and 2 clamps. Took all the hose off and replaced it with the fuel line hose. Less spots to leak and looks cleaner. Cost me 5 bucks.
Old 04-13-2009, 08:19 AM
the issue is the nipple on the block cooling line isn't the same size as the nipple coming off the radiator.
Old 04-13-2009, 08:24 AM
Unertl42's Avatar
yes, you're retarded, just kidding, try the 5/16 hose
Old 04-13-2009, 08:33 AM
ok; is it really worth it; does anyone notice a difference in performance?
Old 04-13-2009, 08:49 AM
what size hose did u use, 5/16?
Old 04-13-2009, 09:29 AM
got-a-ls1's Avatar
i cant imagine this mod making more then 1 hp... how much time does air at full throttle really have to heat up while going through the throttle body? my guess is the air heats up almost none due to the coolant. Whats next block off coolant to the heads because the air will heat up in the intake port? i dunno just never made sense to me... but i guess it wont hurt if you never drive in freezing conditions, i just wouldnt be expecting much.
Old 04-13-2009, 09:42 AM
that is what i was thinking; i'm just going to wait until when/if i install a intake mani and new TB.
thanks guys!
Old 04-13-2009, 09:49 AM
deelong4002's Avatar
when i did my FAST 90 i just bought a whole new hose. I was pissed when i learned they are different diameters. WTF is with that?
Old 04-13-2009, 10:52 AM
teke184's Avatar
go to a marine store
you can buy both size barbed fittings, one with a threaded end, one with a threaded reciever.
i've found them at www.westmarine.com
female
male
not sure the exact sizes needed off hand
Old 04-13-2009, 02:27 PM
tasales06's Avatar
i just used a 5/16 fuel line this weekend and worked great and was easy to install with no leaks at all
Old 04-13-2009, 02:47 PM
female
male
DING DING DING, we have a winner! I believe Loews has them, right next to the one i bought!
I guess i m retarted
Old 04-13-2009, 03:31 PM
Gordo78's Avatar
I just used a coupler, and some hose clamps, no problem here
Old 04-13-2009, 05:04 PM
DaveX's Avatar
Personally I don't think it's worth the time. I don't really think you will gain anything.
Old 04-13-2009, 08:57 PM
TheSilverOne's Avatar
all this does is make removal of the throttle bosy easier
Old 04-13-2009, 10:02 PM
teke184's Avatar
its def one of those ....every little bit helps mods.
it really doesn't do anything benefitial to the engine, alot of guys run the TBB in winter and have no problems. which is why it was designed into the car.
ws6.com got like 4hp with it on the dyno...who knows...
Old 04-14-2009, 06:17 AM
Michael02hawk's Avatar
I'm also using the 5/16" fuel line, since I liked the idea and look of the one piece hose. Works good, just be sure to clamp down the one smaller end on the engine block real good.
Old 04-14-2009, 06:22 AM
dandrea86's Avatar
I used 5/16" hose also...I just cut the end of a vacuum cap off. Stuck it on the 1/4" fitting and then jammed the hose on there. It works great.
