Underdrive pulley worth it?
I've got a few bucks for more mods, and I'm thinking of adding a pulley. My engine is stock (heads, cam, crank etc). Is it worth doing at this point, or should I wait until moving to a serious power adder (FI, h/c)?
Thanks.
Thanks.
LS1Tech Premium Sponsor
8rwhp is what we've seen time & time again. I like the mod, it's easy to do & makes good hp for the $$$.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Moderator
I have line-sag problems with totally stock pulleys
and alternator, on hot days with the A/C on. If
you are in the southland, you may well too unless
you compensate by overspinning the alternator.
It's a shaft RPM, field current limit bind.
I have had mine for alittle over two years now with no issue. I did notice a quicker rev..... sometimes my volt gage drops below 12V but never had battery problems. no after market stereo system here but , I do crank my system at gtg's.....do it!!!!!!
