No more TSP ported 92 FAST intake...well...
As the thread states looks like TSP isnt porting the 92 FAST intakes anymore but offering only 102 mm FAST intakes now....and im guessing they are all unported.
Now i already have a NW 92 mm throttle body, my question is do i need to get a 92 mm FAST from WS6store.com now or can i use a 102 mm FAST?
Car is getting a reverse split cam at the same time if that makes a difference.
Why are you whining, dont run the 102mm on the LSXR if you think its too big.
You can use a 90mm or 92mm on the 102mm LSX. I use a 90mm myself on my LSXR.
Right off the website: "While it features a 102mm air inlet, it can be used with 90mm or 92mm throttle bodies."
LS1Tech Premium Sponsor
I've got two Ported FAST 92's left in stock and ready to go....it will be a little while before we do the engine dyno testing on the new 102 intake and the porting thereof, but you can grab these while they're hot!
Give us a call to order.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Make that ONE of these ported intakes left!
__________________
Noone is whining douchebag, i was simply making a point, no **** , of course u can run a 90 or 92 on an lsx block, just making the point that they should have not stopped producing them because it makes it harder and harder to find used ones, also that the 102 is too much for a 346
I have to admit I am guilty too I wanted a 92 over a 90.,.
so all in all, the 102 is the new universal intake and can be tuned down a little for smaller engines via smaller throttle body. im kind of a "weakest link in the chain" kinda guy, and im guessing it'd basically be a 90 or 92 if thats what TB you put on it. im liking the idea
