removeing crank pully motor want stop turning ???
Old 05-14-2010, 08:57 PM
theskitztikwon's Avatar
Default removeing crank pully motor want stop turning ???
??? i have an auto and i have put it in drive 3rd 2nd and 1st motor still turns ??? im lost with this do i need i strap wrence ?? but what about reinstall the stap wrence want keep it from turning still the pully starts to get snug right
thanx in advance
Old 05-14-2010, 09:10 PM
10 Second Fun Car
jlrz28's Avatar
Putting the auto in gear will not stop it from turning. You will need to either hold the flywheel or the pulley to break the bolt free. I took a puller and installed bolts in it and used a pry bar wedged in between them to push against the floor.
Old 05-14-2010, 09:25 PM
Longshot LCMS's Avatar
Drop the two bolts that hold the starter in and wedge a flat head screwdriver or prybar in to hold the flywheel.
Old 05-14-2010, 09:27 PM
eseibel67's Avatar
The bolts in the pulley method would work, but a fixture that holds the flexplate would be ideal for an auto. It takes quite a mighty bar to break that crank bolt free.
Old 05-14-2010, 09:50 PM
2 ft breaker and 3ft pipe should do the trick im thinking thanx all for the help
Old 05-14-2010, 10:21 PM
Yun Gunz's Avatar
impact?
Old 05-14-2010, 10:56 PM
GMCtrk's Avatar
My solution. Crank bolt comes out in 2 seconds with a 25" breaker bar
Old 05-14-2010, 10:59 PM
10 Second Fun Car
jlrz28's Avatar
Thats exactly what I used and my feet on the garage wall! I thought I broke something when it finally let loose.
Old 05-14-2010, 11:17 PM
Arc00TA's Avatar
I do it the easy mans way, pull the plug wires and put the breaker bar on the bolt and the end against the floor, flick the starter once and its done. I know everyone is going to jump my *** for saying this but its pretty common with a lot of other cars to do this, I learned it from working on jeeps. Putting it back on I just wedged a small prybar in the teeth on the flywheel, held it just fine to torque it on.
Old 05-14-2010, 11:35 PM
LaBLKv6Z's Avatar
I did the same thing on a 2G eclipse, after struggling to stop the crank from turning for awhile, I did a "google search" and was like wtf? really? Put the breaker bar on the bolt and made sure it was wedged against the ground, turned the key for a sec, and that was it lol
Old 05-15-2010, 08:35 AM
clever but did you tear that belt up ??
Old 05-15-2010, 08:43 AM
i dont know if i can feel right doing that no room for any thing to go wrong what if the sockit sliped just a lil and stripedthebolt head ?? its a dd and i have to drive it to tuscaloosa this week (war eagle) for work 2hr away from me id like to try that but cant take the risk
Old 05-15-2010, 09:28 AM
Hulkamania's Avatar
Personally Id use an impact wrench. Normally with an impact you dont have to worry about holding it. Ive seen alot of people break teeth off their flywheel by doing the drop the starter method and wedging something in the teeth. Then your stuck with having to pull the tranny to replace that.
Old 05-15-2010, 12:10 PM
all hand tools here
Old 05-15-2010, 12:38 PM
eseibel67's Avatar
I have a pretty good impact gun (IR231), but it couldn't crack the bolt. Had to use a pipe on the breaker bar.
Old 05-15-2010, 02:18 PM
FOR THE WIN thats whats up didnt even tear up the belt thanx man i still put the pipe on the breaker bar and man that was pretty easy
Old 05-15-2010, 06:03 PM
Justus67's Avatar
Do not use the impact, nothing good could come from this.
