What did you use for block off plates?
Old 10-30-2010, 07:00 PM
Blk_Ws6's Avatar
Default What did you use for block off plates?
Hey fellas an unusual thing happened to me today , put my headers on right , the headers came with the emisson holes , so the qestion is what did you do when you had this problem?
Note: Block off plates don't work theres no thread pattern .
Old 10-31-2010, 01:31 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I used one of the heat sheilds, you gotta use a nut and bolt
Old 10-31-2010, 01:37 AM
01ssreda4's Avatar
Yeah i'm not really understanding the issue here. You bolt the block-off plate to the flange on the header. Simple.
Old 10-31-2010, 03:56 PM
Blk_Ws6's Avatar
no see the headers i have the egr holes on the headers are bigger than the regulars ones, when I put the old egr plates on they was to to small so I have to try and find a way to get this done.
@ Z28 2002 you cut your heat shield and used that ? No leaks huh?
Old 10-31-2010, 04:27 PM
Z28/2002's Avatar
I used some high temp gasket maker and it never leaked
Old 10-31-2010, 06:25 PM
mcalus's Avatar
I used some 20 guage sheet metal, 2 bolts, 2 nuts.
Done... Don't make it harder than it is and don't overthink it.
Old 10-31-2010, 08:33 PM
garygnu's Avatar
use thick paper make a template.get some 1/8 thick plate from home depot,use a thin grinder wheel to cut it out.use a nut & bolt.
Old 11-01-2010, 03:51 AM
Undertow74's Avatar
as stated, Cut your own plates then. get some scrap metal, make a template, draw the outline on the metal then cut it and drill 2 holes and bolt them on.....situation over
Old 11-01-2010, 09:03 AM
bayer-z28's Avatar
Got some block off plates from Speed Inc..
Old 11-01-2010, 09:50 AM
senicalj4579's Avatar
I have some stainless straps used to hang duct work out in the field. I made a couple out of that for my 98 car.
Old 11-01-2010, 11:45 AM
GSus's Avatar
I took a narrow file and slightly elongated one of the holes on the header. Then used nuts and bolts. Took about 15 min.
Old 11-01-2010, 01:54 PM
chrs1313's Avatar
cut them off and have someone weld a small patch on...I have personally seem 3 snap off before and on all types of headers...pacesetters, qtp, and hookers
check this thread out a few down
https://ls1tech.com/forums/generatio...d-headers.html
Old 11-01-2010, 05:31 PM
Blk_Ws6's Avatar
thank yall all fella wouldn't know what to do without yall.
