LS6 or BBK SSI? (intake)
Old 12-18-2010, 06:44 AM
Reno's2fastestfbodys's Avatar
Question LS6 or BBK SSI? (intake)
Ok I currently have a bbk ssi in my hands (thank you!) Now do I trade my buddy for his ls6 or keep it? This is in the near future 243' (or 799) w/ a 228R tsp and bolt on's looking for 450hp/tq. Thoughts? experence? Done dyno on both with proof? Love to know! Need to know! Not just from a stock jock.lol.
Old 12-18-2010, 09:43 AM
nghisus's Avatar
Here's a thread on the BBK SSI:
https://ls1tech.com/forums/generatio...si-intake.html
Horsepower is possible depending on which cam you go with.
Old 12-18-2010, 10:26 AM
Fb0dy0nly's Avatar
Yeah ids swap with ur buddy for the LS6 and call it a day.
MightyMouse has gone 8's with his LS6 intake and has no problems with it. I just think a big metal intake is silly to throw on top of the engine unless you are going to run a lotta n02 thru the bitch or are going sheet metal for high HP apps but that's a different thread.
And please don't turn this into a heat soak metal intake sucks, you'll lose HP pissing match because its ridiculous and there are already 5billion of them floating around you can go whip it out and join the fun in. Sorry just don't the OP to have his thread ruined...
Old 12-18-2010, 11:15 AM
nghisus's Avatar
^agreed^ about the heat soak garbage, can't lose with either one really
Old 12-18-2010, 11:28 AM
Ok solved. Now can I port the tb hole myself?
Old 12-18-2010, 01:23 PM
99Bluz28's Avatar
If your already contemplating a larger TB then just get the BBK, it'll fit a 85mm,and with very little work a 90mm TB. Or just get the LS6 and send it to TPIS and have them install a 90mm snout on it. I've had both and stuck with the BBK, but you can't go wrong either way.
Old 12-18-2010, 08:46 PM
garygnu's Avatar
keep the BBK,and port the intake your self.use some machinist die and mark how much material you need to remove.use a dremel tool .
Old 12-20-2010, 05:39 AM
HoLLo's Avatar
I'd keep the BBK. The BBK intake is worth it if you are spending the money on upgrading from an LS1 intake, not worth it from an LS6 intake from the marginal gains from it.
Old 12-28-2010, 05:16 AM
So I can use a dremal on the ls6 to 80mm? or just stick with the spacer? I'm not a big fan of the bbk. My buddy thinks its the greatest thing ever. Not only that I'm going to paint it. The bbk is a must powder coat and I'm cheep! Thanks guys!
Old 12-28-2010, 05:17 AM
Thrifty* lol
Old 12-28-2010, 06:34 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Swap back to a LS6, the weight penalty alone almost wipes any HP gain from the BBK. If I was really worried about Nitrous Backfires or running some serious BOOST PSI then MAYBE I would consider the intake. But in this case LS6 are cheap and you may get someone to take the BBK off your hands.
I went from a Vengence Ported/Painted 90/90 back to a LS6, on a cash/trade deal and I made out.
Old 12-28-2010, 10:17 AM
01ssreda4's Avatar
I wouldn't have any doubts about spray painting the aluminum BBK.
Old 12-28-2010, 01:43 PM
99Bluz28's Avatar
I used brake cleaner to clean mine up then went over it with high temperature engine paint and it worked great.
Old 12-28-2010, 06:50 PM
mike135531bubba's Avatar
if you can get some cash for it then yeah switch to the ls6. if not, keep the bbk
Old 03-12-2012, 10:52 AM
taman86's Avatar
here check out this thread
https://ls1tech.com/forums/generatio...-intake-2.html
Old 03-12-2012, 10:53 AM
taman86's Avatar
bbk ftw over ls6
Old 03-12-2012, 01:00 PM
2nd Gen Fl 'bird's Avatar
This^^^^^ I completely agree with. As far as the weight thing goes(again), You're are not adding 22 lbs(BBK) to the car. You are adding 12. LS1/LS6 intake=10-11lbs If you added 12lbs to the nose of the car, you would not know it. Or record a time difference.
Quick Reply: LS6 or BBK SSI? (intake)
