Scarpping sound
Old 03-12-2011, 01:33 PM
wicked383lt1's Avatar
Exclamation Scarpping sound
I just finished installing my LT and ory and now I have a scrapping clunking sound underneath the driver seat. It only happens when I take off and not when I'm rolling.What could this be?
Old 03-12-2011, 01:44 PM
mikey1107's Avatar
probably the header collector/y pipe hitting the floor pan when you accelerate. annoying but not a big deal. I just loosened my y and pulled on it until it was a little lower and retightened. or you could fix it by buying a Mufflex bracket. Click here for link It's the last part on the last page of that website.
Old 03-12-2011, 06:48 PM
Originally Posted by mikey1107
probably the header collector/y pipe hitting the floor pan when you accelerate. annoying but not a big deal. I just loosened my y and pulled on it until it was a little lower and retightened. or you could fix it by buying a Mufflex bracket. Click here for link It's the last part on the last page of ethat website.
I tried pulling ory down and nothing...any other suggestions? Before I order that stuff from mufflex. Is it true that this will affect my knock sensor
Old 03-12-2011, 07:36 PM
KevinR's Avatar
Like stated, it's probably your exhaust hitting the bottom of the car. Mine did the same thing after the headers and x pipe were installed.
Old 03-13-2011, 05:14 AM
mikey1107's Avatar
I am sure it can affect the knock sensors.
I also added new motor mounts when I was doing my build which I am sure helps stop mine from banging. You may have to look into doing that also. I just know adjusting my y-pipe was the biggest improvement.
Old 03-13-2011, 09:07 AM
PheonixLS1's Avatar
When I had my duals put in with stock mani's it hit under the drivers side. I just took it back to the shop and they installed an exhaust mount under the seat and welded it to the pipe. Problem solved
Old 03-13-2011, 09:24 AM
fxgs's Avatar
.,,,,, or you could fix it by buying a Mufflex bracket. Click here for link It's the last part on the last page of that website.
That's what I got for my SS Works well........
Old 03-13-2011, 09:35 AM
High_Angle's Avatar
mine did the same thing. turns out it it there is a sheet of metal (silver in color) alongside the driver side that serves no ourpose and the headers were scrapping against it.
easy enough to take off
Old 03-13-2011, 05:52 PM
DaveX's Avatar
It's a common problem and yes it can affect the knock sensors, which will basically cost you power. I tried several different things to cure this problem and finally installed poly motor mounts, which have proven to be the answer for me.
Old 03-13-2011, 06:39 PM
ULTIMATEORANGESS's Avatar
mine was hitting a brace. i just moved it away.
