msd coils!!
msd coils!!
if you have them. tell me what your thoughts are.. summit racing gave such a good deal. an they look awesome.. (msd) has a add on for these coils about out.. which plugs into the extra port.... im happy with them so far.. they power 8000 horsepower nitro cars.. why not let msd spark my ls1!
They look nice and thats all they do. I bought them for my LS1 when i first got my car, worst $600+ i ever spent on my car, that's money you could have spent elsewhere on your car, you won't gain any power, and they will probably go out on you before to long. when i built my new engine i ditched the MSD coils real quick for stock LS7 coils.
if better coils dont make a difference why are people swapping truck coils?
i noticed better throttle responce in my car when i installed mine, people can say what they want, i am very sensitive to subtle changes in my car, i even notice its a little slower when i change the oil as the oil is thicker..
i'm not going to get in a pissing match, do a search. The MSD coil are discussed all the time on here, and it's never anything good. I'll admit i bought them and they were the biggest waste of money ever, hence why i got rid of them, lucky for me, none of my MSD coils went out on me like the dozens and dozens of members on here who have had problems with them.
anything msd is a pure waste,there plug wires are about the obly good thing they make.There distributors are garbage,and there coils are about the biggest rip off item you can buy for an f-body.
^ The truck coils (And MSD too I would think) would be good for a more reliable spark and better idle. Some stock LS1 coils have issues with a miss-fire in the higher RPM ranges. Truck coils would be the more reliable option though. Same benefit for a lot less. And I've read on here that the MSD coils don't last long. That's prolly why the nitro cars use them. They run them for a couple races and throw em out.
^ The truck coils would be good for a more reliable spark and better idle.
actually pro car do run 2 MSD PRO 44 mags, they also run 2 coils.. sorry worked on a few the last 6 years of my life.. anyways..
i enjoy the msd line.. i have had the lsx started since it was out.. amazing torque.. never a issue, the plug wires.. top of the line. great product.. an the coils.. well they have a lot of possibilities..
my msd parts
plug wires 32819
msd aps starter for ls1-ls7 5096
coil set 82458
coil specs
Turns ratio: 52:1
Primary resistance: .57 OHMs
Secondary resistance: 3.1K OHMs
Inductance: 5.8 mH
Maximum voltage: 44,000 Volts
Peak current: 150 mA
Spark duration: 1200 uS
Weight: N/A
Dwell Time: 4.5ms
Current Draw: 8A
these coils also have a extra plug in for a special unit coming soon for ls motors.
my msd parts
plug wires 32819
coil set 82458
coil specs
Turns ratio: 52:1
Inductance: 5.8 mH
Weight: N/A
Dwell Time: 4.5ms
Current Draw: 8A
I haven't had much luck with MSD wires, 3 sets over a period of 5 years.
I will never buy another MSD product, unless it a distributor or ignition system on my 78 T/A, MSD is a complete waste of money on LSX's
anyway OP..... Thanks for the break down of all your MSD products
it's your money to waste, and it's your car, so, as long as your happy right?
