Need help removing crank pulley
Old 09-25-2011, 09:17 PM
UnZFeat'd's Avatar
Default Need help removing crank pulley
I need to remove my crank pulley. I rented the 3 arm puller from autozone and everytime i get it on and start tightening it slips off. I have it tighened so that all the arms are secure. How do you guys get it off? It was easy to get the bolt loose. It is still threaded a tiny bit, just like the ls1howto website says to do. I am really up against the clock here to get this thing done. Help me please
Old 09-25-2011, 09:21 PM
samckitt's Avatar
I used an air impact wrench. Was a PITA, it came off a few times & had to redo, a few F bombs were dropped, but it finally came off.
Old 09-25-2011, 09:27 PM
UnZFeat'd's Avatar
27011 is the part number i have for the 3 arm puller piece of garbage that keeps coming off.
Old 09-25-2011, 09:49 PM
UnZFeat'd's Avatar
That sounds like a way to remove the bolt, which i have had no problems with. My problem is taking the pulley off. The bolt is out, then threaded back in a tiny bit to use for the base of the pulley removal tool.
Old 09-26-2011, 12:50 PM
98 White T/A's Avatar
I'm currently doing my pulley as we speak, i bent the puller from autozone, I bought a 50$ one from sears, much better qaulity and strength, took it right out.
Dont rent the installer from autozone, it wont work. You have 3 options that will work best for you on a ls1.
1. Heat the pulley with a torch a little to help slide it on.
2. Longer crank bolt.
3. Threaded rod with nuts and washers.
Old 09-26-2011, 08:13 PM
JRENIGAR's Avatar
chrysler (dodge product) 3 arm puller rented from oriley auto parts. Hook the arms on the back of the 3 ears on the pulley and bingo first time every time... Hope it works as good for you as it did for me.
Old 09-26-2011, 09:08 PM
If your putting a UD pulley on, let me know how it is after, I just finished mine today and I wasnt totally satisfied.
Old 09-26-2011, 09:56 PM
ls1ya's Avatar
3 arm puller, with the arms hooks works best. Got one for the steering wheel and it worked for the crank pulley.
Old 09-26-2011, 11:12 PM
UnZFeat'd's Avatar
ya i just got the one from autozone too... and bent the **** out of it! then i went back and they gave me a bigger one. why they didnt give me that one in the first place i dont know, but it worked and it is off now.
Old 09-27-2011, 04:47 PM
luna123black's Avatar
like mentioned rent the chrysler puller works great
Old 09-27-2011, 07:32 PM
owndjoo's Avatar
just made one using the bolt and a puller. had to do a little grindin but it worked great
Quick Reply: Need help removing crank pulley
