Fast 102 with LS1 injectors .
Old 12-20-2011, 11:32 AM
_GTO_'s Avatar
Default Fast 102 with LS1 injectors .
Hey guys,
I'm a little confused about the Fast 102 setup on LS1 , I already have an OEM LS2 fuel rail and fast 36 (ls1) injectors , I know the ls1 injector is tall and I’ll have to get a spacer for the rails but the question is , will the (ls1) injectors fit the ls2 rail directly ? What other things I might need?
Thanks.
Old 12-21-2011, 03:23 AM
_GTO_'s Avatar
Anyone ??
Old 12-21-2011, 05:22 AM
Unertl42's Avatar
no, LS2 injectors are shorter, and have a different plug. The rail won't sit on the intake so you can bolt it down. There is an adapter kit to make it work, I can't remember who sells it, but the magic Google knows
Old 12-21-2011, 05:24 AM
Unertl42's Avatar
****, I just re-read your post. You should be good, you have the adapter kit, and other than that, it should be plug and play
Old 12-21-2011, 08:16 AM
DBShocker's Avatar
^he ment crap, not **** lol
Old 12-21-2011, 08:39 AM
SweetS10V8's Avatar
You need;
Lower orings (comes with 146302 manifold)
Spacers (between fuel rails and manifold)
Bolts (for fuel rail/spacer/manifold)
Washers
Your basically making a 146021-KIT but using your own fuel rails. Call FAST and get the extra parts. They have them already.
Old 12-21-2011, 10:04 AM
themealonwheels's Avatar
Originally Posted by SweetS10V8
You need;
Washers
Hey bud, you may remember you answered someone in the fueling section on this site on this topic... I replied that I thought my LS1 lower o-rings would work? Well turns out you were right and I found the correct o-rings in the box with the manifold. So stock LS1 lower o-rings work on a Typhoon, but NOT the FAST (just for clarification)!
On the LS1 injector on the LS2 rails, shouldn't we convert to an LS2 top o-ring? I asked for 06 GTO top o-rings at the parts store, and they are definitely beefier. I test fitted them in my LS2 fuel rail, and they fit well, haven't tested the LS1 o-rings in the LS2 rail... thoughts?
Old 12-21-2011, 10:38 AM
SweetS10V8's Avatar
Ive run the LS1 style injectors in the LS2 rails, without swapping the upper oring, a ton of times.
Never had a failure.
Old 12-21-2011, 12:52 PM
_GTO_'s Avatar
You need;
Washers
So , The lower o ring are coming with the intake and I can use the upper ls1 o ring with ls2 fuel rail .
All I need now is the Bolts and spacers .
Thank you very much your help SweetS10V8 .
Old 12-21-2011, 05:48 PM
SweetS10V8's Avatar
And lock washers.... Your welcome!!!
Oh yeah, the orings only come with the cathedral port intake #146302. So if you did an LS3 head swap, and planning on using the LS3 FAST #146102, youll need to order the orings seperate as well.
Old 12-21-2011, 07:27 PM
_GTO_'s Avatar
I'll get the cathedral ports intake and not planning to switch to rectangular ports .
Cathedral port heads FTW
Thanx again .
Old 03-04-2013, 03:17 PM
barracuda_440's Avatar
What about for those of us that did not get the Orings with our used fast 102 intake. I was told the lower orings from a 94-95 5.0 mustang work on the ls1 injector and the 102 intake
Old 03-23-2013, 05:51 PM
Violatorno1's Avatar
This is a good question. Does anyone have a part number or know exact make/model/yr of car to order a set for? About to get my setup installed but need lower o-rings.
Old 12-21-2015, 03:22 AM
JIMS SVT's Avatar
Anyone figure this out?
Old 01-02-2016, 02:10 PM
sick_ss camaro's Avatar
I am about ready to install my fast 102 intake on my ls1 and am in need of the same information about lower o'rings needed for ls1 injectors? Anyone?
Old 01-02-2016, 02:37 PM
7mmx4mm for lower orings. I have spares, pm me if you need a set
Old 01-12-2016, 12:07 PM
I would like a set of these lower injector o-rings and spacers if I need them. I'm new to the page I do not know how to message sorry for inconvenience
Old 02-07-2016, 01:00 AM
Ok so thanks for the info and sending me the lower o rings .I attempted to mount fuel rails on the intake and apparently need the spacers as well as I stated in earlier post.. I assumed I was getting the spacers as well ..so can I get some help with the spacers.please
Old 02-07-2016, 08:35 AM
If you need the spacers to supplement the orings, shoot me back a pm and we can work out a price
Old 02-07-2016, 08:46 AM
I tried to send a message again not sure why its not going through ...but as I stated in my earlier post I was looking for the ( o rings and the spacers ) im not sure what the problem was with the communication but didn't get what I needed now I am more than frustrated trying to put this together without having what I need.
Quick Reply: Fast 102 with LS1 injectors .
