ps pump delete
Old 08-23-2014, 01:24 PM
Mr Phil's Avatar
Default ps pump delete
I'm wanting to just get rid of the power steering. Idk where the leak is coming from but it's already killed two alternators and I just want it gone
I already have the belt and pulley replacement from this picture I pulled from another website
But I can't find any info on how to remove everything. Are there any holes or anything I'll need to plug up?
If anyone can help me with what I'll need or just give me a link that actually gives step by step instructions that would be great.
98 trans am, I just want it gone. I know it's not dd friendly but oh well
Old 08-24-2014, 02:57 AM
Mr Phil's Avatar
Is this not in the right section or what? Or does nobody know
Old 08-24-2014, 08:03 AM
Mike Warner's Avatar
I run what you have pictured and did not even put ribbed pulley on idler . There are no holes to plug on my Ls3. I just used smooth pulley on idler. I have had no problem.
Mike
Old 08-24-2014, 10:16 AM
Mr Phil's Avatar
What about on the rack where the lines and everything go into? Wouldn't there be exposed holes?
Old 08-24-2014, 12:39 PM
Cstone812's Avatar
Loop the lines together or leave open. Leaving the holes open leaves the rack open to dirt and debris that can destroy the rack though. Don't plug the holes.
Old 08-24-2014, 12:50 PM
"MAC"'s Avatar
Get a mustang rack or order a manual rack. Its actually a little bit lighter iirc. Assuming you didn't already delete the ps pump cooler just get a new radiator hose going from the top of the radiator to the engine.
Old 08-24-2014, 12:57 PM
Mr Phil's Avatar
I read somewhere the 98/99 ta/z28 didn't have ps cooler.... If I had one where would it be? And no I haven't removed anything yet, it was WAY too hot yesterday, and I'm lazy today as I have work tonight lol
Old 08-24-2014, 01:01 PM
"MAC"'s Avatar
My bad i didn't see the year lol so your probably right. All ya need to do is follow the lines to find out. But you can order the new rack from Summit or try and find a manual rack in the junk yard.
Old 08-24-2014, 01:42 PM
Mr Phil's Avatar
Why would u say loop the lines or leave them open but don't plug them? If leaving the holes open could damage it, why wouldn't I want to cap/plug them
The following users liked this post:
fastsspr (03-12-2023)
Old 08-24-2014, 01:54 PM
Cstone812's Avatar
If you plug the holes pressure will build up in the rack and you won't be able to turn. Just loop the lines together like everyone else does.
Old 08-24-2014, 02:35 PM
Mr Phil's Avatar
Do you have any pictures of the set up on where they are setting things up at?
Old 08-24-2014, 03:00 PM
"MAC"'s Avatar
They are pressured lines so itll leak if you loop them together
Old 08-24-2014, 04:21 PM
Cstone812's Avatar
Pull lines drain most of the fluid then put back on and loop together.
Old 08-24-2014, 11:22 PM
Mr Phil's Avatar
Ok again, do you have any pictures of the loop together results? I'm not sure I'm understanding what u mean
Old 08-25-2014, 12:05 AM
Majestic9C1's Avatar
there should be 2 ports on the rack.. one from the pressure hose and one from the return hose..
just stick some NPT barbed fittings in them and connect the two with some heater hose..
Old 08-25-2014, 10:03 AM
Jake the SSnake's Avatar
Here's a thread from back when I did it with pics. It's kind of expensive, but it works and is still on the car. I'll probably be "reversing" the procedure in a few months though.
https://ls1tech.com/forums/drag-raci...rocedures.html
Old 08-25-2014, 04:10 PM
Mr Phil's Avatar
Awesome thanks... but what are these lines too right here? When I was mocking up my set up with the pulley and belt, there was a bracket or something attached to the two lines I have circled that were touching the belt and most likely would have rubbed against it and cut belt in half
Old 08-25-2014, 04:12 PM
"MAC"'s Avatar
Transmission lines
Old 08-25-2014, 04:28 PM
Mr Phil's Avatar
Why doesn't he have whatever bracket that I have that was rubbing against the belt?
Old 08-26-2014, 07:55 PM
It might have been rubbing the belt so I removed it, I honestly don't remember it's been so long. My tranny lines do move a little, but I don't think it's a big deal.
Quick Reply: ps pump delete
