Kooks Racing Headers with Factory LS1 Intake
So I recently bought some Kooks 1 7/8 Headers. I got them and it turns out they were Racing headers. In the long run this is probably for the best, as I'll eventually (not the near future) upgrade to a Fast Intake. However, right now I the factory LS1 Intake in my 02 WS6 and thus have emission components and no where to connect them.
Is there a mod for getting rid of these emissions components on my intake that'll allow me to run this setup without throwing a code?
Or am I screw and will need to either get the regular headers or upgrade my intake???
Thanks in advanced!!!
That's awesome! Thanks!!! After a little research, I just need to remove a pump, some air hose, and annoying egr thingamagiga, and put a vacum cap on the back of my intake and I'm GTG correct? Oh and a tune.
https://ls1tech.com/forums/new-ls1-o...air-tubes.html
And a even better time to change your motor mounts. Seriously it should almost be considered mandatory so install poly MM's when you install headers for 2 reasons, it's a big pain in the *** job thats not so bad when everything is already torn apart for the header install, and stock 12yr old rubber one's will probably flex enough that you header collector or y pipe will bang on the floor pan.
Definitely is a must! Either Polys or Solids should go in...I have had 4 F-bodies and skipped doing motor mounts on 1 while installing QTP LTs...never again, y-pipe banged the floor pan like a sailor banging a Thai hooker....
Should have left the motor mounts alone
So I was almost done with these mods. I was 24 hrs from having my car back on the road. All I needed to do was get the passenger side mount lined up and bolt a few more things back up.
In this process me and a buddy (after a couple hours of trying) decided to loosen the motor mount that attaches to the subframe. Did this on the other side and it worked great other than the one bolt that was a PITA to get back in.
In this process I snapped the lower front bolt holding the mount to the subframe. I have about 1/8" to 1/4" of a stud sticking out of the subframe. Oh did I mention I don't have the tools needed to remove the subframe (cherry picker, lift plate).
I'm thinking about drilling a hole in the subframe from underneath just below the bolt to get to the stud so I can drill it out. Any thoughts?
Oh and I should add that the mounts looked to be in pretty good shape for a 50k car let alone my 100k car.
