243 heads? what intake?
just had my car dyno'd yesterday. has a custom ground cam that was in it when i got it and do not know the numbers on it and can't get them due to thunder raceing closeing, and headers, put down 338hp before tune and 355hp after, wanna put a set of heads on and an intake now and get over the 400 mark. heard 243's ported and polished are a good way to go and what would be a good intake? also the heads come on the 5.3s? and what years. thanks
LS1Tech Premium Sponsor
^ agreed. If you want to know the cam specs, the grind#'s / serial # should be ground on the cam. You can relay those numbers to Comp Cams and they can get you the cams specs.
Lonnie
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
