weird idle
Old 03-30-2005, 06:00 PM
tuffluck's Avatar
Default weird idle
my car idled at 1400 yesterday, then at 800 this morning (normal), and now at 1000. i don't know what's going on. from what i can tell everything looks good engine-wise. all i have is a lid, and i haven't done anything but add a little bit of oil in the last 6 months. no ses light either. anyone have a clue?
Old 03-31-2005, 11:58 AM
Ragtop 99's Avatar
Make sure you don't have a vacuum leak somewhere on the intake.
Old 04-05-2005, 01:31 PM
tuffluck's Avatar
it's still doing it. i can't find a vacuum leak. it will idle normal for a few days, then it'll go back up to 1400 and slowly work it's way down. i pulled my pcm eng and ign fuse also, and that didn't cure the problem. please, anyone have any idea what the heck is going on?
Old 04-05-2005, 09:25 PM
72ChevelleConv.LS1's Avatar
Try TPS throttle position senser This should be on the throttle body. un plug and see if it goes up or down. could be bad
Old 04-06-2005, 12:00 AM
tuffluck's Avatar
what does it look like? so i unplug it and then plug it back in, or i just unplug it?
has anyone ever experienced a similar problem?
Old 04-06-2005, 12:40 AM
TransAm52804's Avatar
I've got the EXACT same problem going on. Any help will be much appreciated.
Old 04-06-2005, 12:05 PM
tuffluck's Avatar
well then, ttt for us both!!
Old 04-06-2005, 03:35 PM
oange ss's Avatar
check pcv valve area for leaks
Old 04-06-2005, 03:43 PM
bad0211secws6's Avatar
make sure the clamp is tight around the maff to the lid sometimes its hard to get it tight enough since the lid is hard plastic it may be throwing your air flow readings off
Old 04-06-2005, 04:09 PM
BBQLS1's Avatar
Idle Air Bypass?
Old 04-08-2005, 02:38 PM
tuffluck's Avatar
i'm not really sure how to check for leaks, but i definitely don't hear any leaks.
btw, it's starting to idle at 1400 only after 20+ minute drives. if i just make a quick trip it will not do this. i'm very confused and concerned.
