Is a cooler thermostat worth it?
I'm thinking of going to a cooler thermostat. I was thinking of the Vinci 170 degree version. Currently, my fans are set such that the warmest the car ever gets is 207 degrees. That is with a stock thermostat, in stop-and-go traffic. Normal running temps are 192-194 degrees. Would a cooler running thermostat buy me anything at all? BTW, I have a heads and cam car. Experiences, and opinions, all welcome. thanks! :cheers
Ed
Ed
Originally Posted by camaro-man
I thought that if you get your engine running too cool it would cause problems, not help anything. Who knows though I could be wrong!
finally, the best HP is usually seen with water temps of about 160degrees and oil temps of about 210degrees.....
LS1Tech Administrator
Received 1,794 Likes
Lots of info on this, been discussed in depth and good points made on both sides. Try a search.
Personally, I see no point in running coolant temps any cooler than 185-190 on a stock compression, NA LS1. I've tried it and seen no gains, only a loss in MPG. To each his own......
Moderator
All in all I'd say you'd do better with stock 'stat,
smart fan settings and a better radiator. Radiator
costs can be low, I snarfed a LT1 rad off eBay for
$25 never-wet (cost less than the shipping). The 160
thermostats demand a -way- better radiator if you
want to keep the temp there, under load with A/C
on. The goal is to minimize temp swing and at high
loads the thermostat is no part of the thermal-dump
limitation.
Better to have rock-solid 195F than a 175-225F
bouncing ball, for tuning it down to the bone.
limitation.
I had used a Hypertech (now stollen) to set my fans to come on at 180 with a 160-stat inside. I'm getting a Vinci handheld in a few days in the mail but I noticed the lowest temp for fan turn-on is 190 (!)
Will Vinci overwrite Hypertech's coding or will it stack?
I have the Hypertech 160* thermostat and have had my fans programed to 180 for the low and 188 for the high speed. I live in Houston, Tx and it gets pretty damn hot here. If I would have lived up north, I probably would have went with a 180* thermostat.
