Did Pacesetter lt's yesterday
Old 04-15-2006, 03:49 PM
98RedZone's Avatar
Default Did Pacesetter lt's yesterday
Everything went easier than expected, lots of help from reading all the posts on here. I got rid of the AIR and EGR. I was confused on the "frost plug" for the EGR until I read more this morning. The one I ended up getting was actually called an expansion plug, 1 3/8"-1 1/2" diameter. We put both headers in from the bottom, removed the #5 cylinder spark plug to get the driver side in. Only problem was getting the oil dipstick tube out, it didn't break, but I mangled the end pretty good and have a new one ordered.
Old 04-15-2006, 03:54 PM
stevensLS1's Avatar
congrats man! did you put an ory or catted? about how long did all this take?
Old 04-15-2006, 04:11 PM
98RedZone's Avatar
ORY with race style coated headers. About six hours with one person helping, including removing the emissions stuff.
Old 04-15-2006, 04:13 PM
00TAProject's Avatar
I did the same.....I have yet to get another one, but I will soon.....
Old 04-15-2006, 04:25 PM
joecar's Avatar
Picture of old one...?
Old 04-15-2006, 06:29 PM
GR33N GoblinM6's Avatar
why do you have to remove the dipstick???
Old 04-15-2006, 07:03 PM
bastien's Avatar
congrats. I am sure you will enjoy it
Old 04-15-2006, 08:35 PM
Shallow Bay's Avatar
Where did you order a new one from?
Old 04-15-2006, 08:42 PM
jmm98LS1's Avatar
Because it runs in between the primary tubes for #4 and #6 cylinders.....can't remove/install headers with it in place.
Old 04-15-2006, 10:51 PM
98RedZone's Avatar
Dealership. I didn't even ask the price, but the "list" price on gmpartsdirect.com was $8.99.
Old 04-16-2006, 12:32 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
BAd ***!
Old 04-16-2006, 11:27 AM
so do you have to drain your oil to do this? and how do you remove your dipstick?
Im asking because i ordered pacesetters and I just want a heads up..
Old 04-16-2006, 01:06 PM
98RedZone's Avatar
No, you dont have to drain the oil. I think it actually goes into the block right above the pan, around the front of the starter. There is a bolt in the head you take out, then just pull on it. Hopefully your comes out easier than mine, I ended up grabbing it with channel locks, and I still had to pull hard, and try twisting and rotating it.
Old 04-16-2006, 01:14 PM
blackbird00's Avatar
i took mine out also but for got to screw it back in so its sitting there loose but it wont go anywhere and you really cant even tell. unless u tug on it
Old 04-16-2006, 01:40 PM
ok... anything else that has to be removed when installing these headers?
Old 04-16-2006, 02:13 PM
erikthegoalie's Avatar
EASY, unbolt the 15MM bolt i think it is...maybe 13..i think its 15...
and pull up gently....it will come!!!! DO NOT BEND IT!!!
it was CAKE
e
Old 04-16-2006, 02:14 PM
i removed my coil packs....just to make it that muchj easier...probably another hour in the project taking your sweet *** time..made things easy, plus i did new wires and all soooo
try it
